toolchain version
hello everybody
who could please share with me the newest toolchain version for
beagleboard ? 2007q1-21 ?
thank you
aung
Sourcery G++ Lite 2007q3-53 for ARM EABI should be the right one:
http://www.codesourcery.com/gnu_toolchains/arm/portal/release316
Matthieu.
there is also a patch to stock gcc 4.3.1 to fix the ICE with -mfpu=neon, has
anybody given that a good workout?
thank you for your information , i start from 2007q3-53 .
Regards
Aung
I met some problem when i build u boot by 2007q3-53 and my uboot is u-
boot_beagle_revb[1].tar.gz
error message as below , any thing i forget to do?
                        --start-group lib_generic/libgeneric.a cpu/
omap3/libomap3.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/
libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/
libreiserfs.a fs/ext2/libext2fs.a net/libnet.a disk/libdisk.a drivers/
bios_emulator/libatibiosemu.a drivers/block/libblock.a drivers/dma/
libdma.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/
libinput.a drivers/misc/libmisc.a drivers/mtd/libmtd.a drivers/mtd/
nand/libnand.a drivers/mtd/nand_legacy/libnand_legacy.a drivers/mtd/
onenand/libonenand.a drivers/net/libnet.a drivers/net/sk98lin/
libsk98lin.a drivers/pci/libpci.a drivers/pcmcia/libpcmcia.a drivers/
spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/
usb/libusb.a drivers/video/libvideo.a common/libcommon.a libfdt/
libfdt.a api/libapi.a post/libpost.a board/omap3530beagle/
libomap3530beagle.a --end-group -L /opt/arm-2007q3/bin/../lib/gcc/arm-
none-eabi/4.2.1 -lgcc -lgcc_eh \
                        -Map u-boot.map -o u-boot
arm-none-eabi-ld: cannot find -lgcc_eh
I'm also a newbie as far as Sourcery is concerned (< 24 hours
experience, no kernel or Uboot builds), but this might be useful:
The linker is looking for libgcc_eh.a and is failing to find it in .../
lib/gcc/arm-none-eabi/4.2.1.
I've downloaded two versions of G++ Lite:
1. arm-none-eabi 2007q3-53 is for building low-level applications
such as Uboot and Linux Kernel image that don't have an underlying
operating system.
2. arm-none-linux-gnueabi 2007q3-51 is for building Lunix
applications such as user code that runs on Ångström. I've used this
successfully for both "Hello, world" and a simple X11 application,
running on top of Koen's Ångström demo.
arm-none-eabi 2007q3-53 does not seem to have library libgcc_eh.a.
On the other hand, arm-none-linux-gnueabi 2007q3-51 does have it in
several locations.
You might try removing "-lgcc_eh" from the gcc (ld) command and see if
it's really needed by Uboot.
John
arm-none-eabi is the wrong toolchain.
Did you edit U-Boot's makefile to compile with arm-none-eabi?
Just tried it, boot_beagle_revb.tar.gz compiles fine with
arm-none-linux-gnueabi-gcc.
Correct compiler is
-- cut --
arm-none-linux-gnueabi-gcc -v
Using built-in specs.
Target: arm-none-linux-gnueabi
Configured with: /scratch/paul/lite/linux/src/gcc-4.2/configure
--build=i686-pc-linux-gnu --host=i686-pc-linux-gnu
--target=arm-none-linux-gnueabi --enable-threads --disable-libmudflap
--disable-libssp --disable-libgomp --disable-libstdcxx-pch
--with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared
--enable-symvers=gnu --enable-__cxa_atexit
--with-pkgversion=CodeSourcery Sourcery G++ Lite 2007q3-51
--with-bugurl=https://support.codesourcery.com/GNUToolchain/
--disable-nls --prefix=/opt/codesourcery
--with-sysroot=/opt/codesourcery/arm-none-linux-gnueabi/libc
--with-build-sysroot=/scratch/paul/lite/linux/install/arm-none-linux-gnueabi/libc
--enable-poison-system-directories
--with-build-time-tools=/scratch/paul/lite/linux/install/arm-none-linux-gnueabi/bin
Thread model: posix
gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)
-- cut --
Btw, better you use Steve's U-Boot git instead of
boot_beagle_revb.tar.gz. It has some fixes.
http://www.sakoman.net/cgi-bin/gitweb.cgi?p=u-boot-omap3.git;a=shortlog;h=refs/heads/test
Dirk
operating system.
From technology point of view, this is correct. But for Beagle you
don't need this. We build everything (U-Boot, Kernel and user space)
with arm-none-linux-gnueabi and this is fine. So you don't need
arm-none-eabi.
Use this for everything (U-Boot, kernel and apps).
several locations.
Better use arm-none-linux-gnueabi. Will be easier unless you are
interested in U-Boot optimization.
Dirk
Dirk,
Thank you for clearing this up.
I was mislead by the 2nd post in this topic and also by the
BeagleBoard Wiki
http://elinux.org/BeagleBoard#Compiler which recommends 2007q3-53
(which is bare-metal EABI) instead of 2007q3-51 (Linux/GNU EABI).
John
John Beetem wrote:
Dirk,
BeagleBoard Wiki
It talks about "ARM GNU/Linux tool chain"
Thanks for the hint, I never looked so detailed at the 5x numbers :wink:
Wiki want to say "use ARM GNU/Linux tool chain 2007q3 version".
Do you like to correct this?
Dirk
I've never done Wiki updates, and I'd rather leave it to someone who
has had more than just a few hours of experience with Sourcery :slight_smile:
sorry I've made the mistake in the second post, so I've fixed the
Wiki.
Matthieu.
Dear All
thank you , I solve it now.
Regards
Aung
2008/8/17, mpoullet <matthieu.poullet@gmail.com>:
