hello all,
i was facing the problem on touchscreen in devkit8000 .
but lcd display is working,
my kernel is from rowboat-android,
but i did compile this kernel with arm-2007q1 toolchain
please give me suggestion how to solve this on.thank you in advance.
and this kernel image is working fine on beagleboard .
here filesystem is anstromg.
once see the below log from devkit8000
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 DevKit8000 Board + LPDDR/NAND
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
reading uImage
3313860 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.32
Data Size: 3313796 Bytes = 3.2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................................................................................................................................
[ 0.000000] Linux version 2.6.32 (venkatraju@localhost.localdomain)
(gcc version 4.2.0 20070413 (prerelease) (CodeSourcery Sourcery G++
Lite 2007q1-10)) #115 PREEMPT Tue Oct 12 17:31:21 IS0
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 noinitrd
root=/dev/mmcblk0p2 rootfstype=ext3 rw rootdelay=1 nohz=off init=/sbin/
init video=omapfb:mode:4.3inch_LCD omapdss.def_disp=2
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 238208KB available (6100K code, 701K data, 184K
init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/266/500 MHz
[ 0.000000] Reprogramming SDRC clock to 266000000 Hz
[ 0.000000] dpll3_m2_clk rate change failed: -22
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 11.431243] OMAP DMA hardware revision 4.0
[ 11.441833] bio: create slab <bio-0> at 0
[ 11.443511] SCSI subsystem initialized
[ 11.445373] usbcore: registered new interface driver usbfs
[ 11.445556] usbcore: registered new interface driver hub
[ 11.445800] usbcore: registered new device driver usb
[ 11.461761] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 11.465026] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 11.465057] twl4030: power (irq 373) chaining IRQs 376..383
[ 11.465454] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 11.467468] regulator: VUSB1V5: 1500 mV normal standby
[ 11.467773] regulator: VUSB1V8: 1800 mV normal standby
[ 11.468078] regulator: VUSB3V1: 3100 mV normal standby
[ 11.469757] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 11.470336] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 11.470672] regulator: VDAC: 1800 mV normal standby
[ 11.471038] regulator: VPLL2: 1800 mV normal standby
[ 11.471374] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 11.471557] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 11.471832] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 11.473937] Switching to clocksource 32k_counter
[ 11.487121] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 11.490081] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 11.491027] NET: Registered protocol family 2
[ 11.491302] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 11.491973] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 11.492248] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 11.492370] TCP: Hash tables configured (established 8192 bind
8192)
[ 11.492401] TCP reno registered
[ 11.492431] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 11.492462] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 11.492767] NET: Registered protocol family 1
[ 11.493347] RPC: Registered udp transport module.
[ 11.493347] RPC: Registered tcp transport module.
[ 11.493377] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 11.494598] omap-iommu omap-iommu.0: isp registered
[ 11.506286] VFS: Disk quotas dquot_6.5.2
[ 11.506408] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 11.507812] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 11.508880] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red
Hat, Inc.
[ 11.509918] msgmni has been set to 465
[ 11.515594] alg: No test for stdrng (krng)
[ 11.515991] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 253)
[ 11.516021] io scheduler noop registered
[ 11.516021] io scheduler deadline registered
[ 11.516235] io scheduler cfq registered (default)
[ 11.575714] OMAP DSS rev 2.0
[ 11.575805] OMAP DISPC rev 3.0
[ 11.575866] OMAP VENC rev 2
[ 11.576171] OMAP DSI rev 1.0
[ 11.916748] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 11.938446] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 11.959136] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 11.979797] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 12.475952] console [ttyS2] enabled
[ 12.488647] brd: module loaded
[ 12.496307] loop: module loaded
[ 12.501098] omap2-nand driver initializing
[ 12.505645] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 12.514892] cmdlinepart partition parsing not available
[ 12.520172] Creating 5 MTD partitions on "omap2-nand":
[ 12.525421] 0x000000000000-0x000000080000 : "X-Loader"
[ 12.532104] 0x000000080000-0x000000260000 : "U-Boot"
[ 12.538909] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 12.545257] 0x000000280000-0x000000680000 : "Kernel"
[ 12.552917] 0x000000680000-0x000010000000 : "File System"
[ 12.665496] usbcore: registered new interface driver catc
[ 12.670989] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 12.677062] usbcore: registered new interface driver kaweth
[ 12.682708] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 12.690368] usbcore: registered new interface driver pegasus
[ 12.696105] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 12.703155] usbcore: registered new interface driver rtl8150
[ 12.708984] usbcore: registered new interface driver asix
[ 12.714508] usbcore: registered new interface driver cdc_ether
[ 12.720520] usbcore: registered new interface driver cdc_eem
[ 12.726379] usbcore: registered new interface driver dm9601
[ 12.732147] usbcore: registered new interface driver smsc95xx
[ 12.738006] usbcore: registered new interface driver gl620a
[ 12.743774] usbcore: registered new interface driver net1080
[ 12.749633] usbcore: registered new interface driver plusb
[ 12.755249] usbcore: registered new interface driver rndis_host
[ 12.761352] usbcore: registered new interface driver cdc_subset
[ 12.767425] usbcore: registered new interface driver zaurus
[ 12.773193] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 12.781311] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 12.788299] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 12.794525] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 12.802154] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 12.817871] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 12.823791] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 12.830688] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 12.838012] usb usb1: Product: OMAP-EHCI Host Controller
[ 12.843383] usb usb1: Manufacturer: Linux 2.6.32 ehci_hcd
[ 12.848815] usb usb1: SerialNumber: ehci-omap.0
[ 12.854278] hub 1-0:1.0: USB hub found
[ 12.858154] hub 1-0:1.0: 3 ports detected
[ 12.888275] Initializing USB Mass Storage driver...
[ 12.893371] usbcore: registered new interface driver usb-storage
[ 12.899475] USB Mass Storage support registered.
[ 12.904785] mice: PS/2 mouse device common for all mice
[ 12.910583] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 12.918823] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 12.930572] using rtc device, twl_rtc, for alarms
[ 12.935272] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 12.941864] twl_rtc twl_rtc: Power up reset detected.
[ 12.947418] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 12.952362] i2c /dev entries driver
[ 12.956756] Linux video capture interface: v2.00
[ 12.961853] omap-iommu omap-iommu.0: isp: version 1.1
[ 12.968811] zc0301: V4L2 driver for ZC0301[P] Image Processor and
Control Chip v1:1.10
[ 12.977020] usbcore: registered new interface driver zc0301
[ 12.982666] gspca: main v2.8.0 registered
[ 12.987243] usbcore: registered new interface driver uvcvideo
[ 12.993072] USB Video Class driver (v0.1.0)
[ 12.997283] vpfe_init
[ 13.000366] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 13.115020] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 13.122131] Registered led device: beagleboard::usr0
[ 13.127349] Registered led device: beagleboard::usr1
[ 13.133605] Registered led device: beagleboard::pmu_stat
[ 13.141540] usbcore: registered new interface driver usbhid
[ 13.147216] usbhid: USB HID core driver
[ 13.151306] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 13.159973] usbcore: registered new interface driver snd-usb-audio
[ 13.208648] No device for DAI omap-mcbsp-dai-0
[ 13.213134] No device for DAI omap-mcbsp-dai-1
[ 13.217651] No device for DAI omap-mcbsp-dai-2
[ 13.222106] No device for DAI omap-mcbsp-dai-3
[ 13.226623] No device for DAI omap-mcbsp-dai-4
[ 13.231109] OMAP3 Beagle SoC init
[ 13.236297] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 13.249420] OMAP3 omap3devkit8000 SoC init
[ 13.253631] ------------[ cut here ]------------
[ 13.258392] WARNING: at fs/sysfs/dir.c:477 sysfs_add_one
+0x108/0x134()
[ 13.265014] sysfs: cannot create duplicate filename '/devices/
platform/soc-audio'
[ 13.272552] Modules linked in:
[ 13.275695] [<c003bda4>] (unwind_backtrace+0x0/0xdc) from
[<c00667d8>] (warn_slowpath_common+0x4c/0x68)
[ 13.285217] [<c00667d8>] (warn_slowpath_common+0x4c/0x68) from
[<c0066830>] (warn_slowpath_fmt+0x28/0x38)
[ 13.294891] [<c0066830>] (warn_slowpath_fmt+0x28/0x38) from
[<c0137d10>] (sysfs_add_one+0x108/0x134)
[ 13.304138] [<c0137d10>] (sysfs_add_one+0x108/0x134) from
[<c01382dc>] (create_dir+0x4c/0x98)
[ 13.312774] [<c01382dc>] (create_dir+0x4c/0x98) from [<c0138364>]
(sysfs_create_dir+0x3c/0x54)
[ 13.321502] [<c0138364>] (sysfs_create_dir+0x3c/0x54) from
[<c024aec0>] (kobject_add_internal+0xe0/0x1bc)
[ 13.331176] [<c024aec0>] (kobject_add_internal+0xe0/0x1bc) from
[<c024b440>] (kobject_add+0x50/0x64)
[ 13.340423] [<c024b440>] (kobject_add+0x50/0x64) from [<c02ace0c>]
(device_add+0x94/0x494)
[ 13.348815] [<c02ace0c>] (device_add+0x94/0x494) from [<c02b0fb4>]
(platform_device_add+0xf8/0x154)
[ 13.357971] [<c02b0fb4>] (platform_device_add+0xf8/0x154) from
[<c0028234>] (omap3devkit8000_soc_init+0x6c/0xa8)
[ 13.368286] [<c0028234>] (omap3devkit8000_soc_init+0x6c/0xa8) from
[<c003636c>] (do_one_initcall+0x54/0x198)
[ 13.378234] [<c003636c>] (do_one_initcall+0x54/0x198) from
[<c0008888>] (kernel_init+0x9c/0x118)
[ 13.387115] [<c0008888>] (kernel_init+0x9c/0x118) from [<c0037910>]
(kernel_thread_exit+0x0/0x8)
[ 13.396026] ---[ end trace 0ff9b96873792cee ]---
[ 13.400695] kobject_add_internal failed for soc-audio with -EEXIST,
don't try to register things with the same name in the same directory.
[ 13.413269] [<c003bda4>] (unwind_backtrace+0x0/0xdc) from
[<c024af3c>] (kobject_add_internal+0x15c/0x1bc)
[ 13.422943] [<c024af3c>] (kobject_add_internal+0x15c/0x1bc) from
[ 13.432281] [<c024b440>] (kobject_add+0x50/0x64) from [<c02ace0c>]
[ 13.440643] [<c02ace0c>] (device_add+0x94/0x494) from [<c02b0fb4>]
[ 13.449798] [<c02b0fb4>] (platform_device_add+0xf8/0x154) from
[ 13.460113] [<c0028234>] (omap3devkit8000_soc_init+0x6c/0xa8) from
[ 13.470062] [<c003636c>] (do_one_initcall+0x54/0x198) from
[ 13.478942] [<c0008888>] (kernel_init+0x9c/0x118) from [<c0037910>]
[ 13.487823] Unable to add platform device
[ 13.491882] ALSA device list:
[ 13.494873] #0: omap3beagle (twl4030)
[ 13.498901] oprofile: using arm/armv7
[ 13.502899] TCP cubic registered
[ 13.506225] NET: Registered protocol family 17
[ 13.510742] NET: Registered protocol family 15
[ 13.515380] lib80211: common routines for IEEE802.11 drivers
[ 13.521118] ThumbEE CPU extension supported.
[ 13.525421] Power Management for TI OMAP3.
[ 13.530090] usb 1-1: new high speed USB device using ehci-omap and
address 2
[ 13.537841] SmartReflex driver initialized
[ 13.552703] omap2_clk_init_cpufreq_table: failed to initialize
frequency
table
[ 13.561004] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 13.569732] registered taskstats version 1
[ 13.591522] Console: switching to colour frame buffer device 60x37
[ 13.609008] regulator_init_complete: incomplete constraints,
leaving VDVI on
[ 13.616302] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 13.624145] twl_rtc twl_rtc: setting system clock to 2000-01-01
00:00:00 UTC (946684800)
[ 13.632537] omap_vout omap_vout: probed for an unknown device
[ 13.638610] Waiting 1sec before mounting root device...
[ 13.733581] usb 1-1: New USB device found, idVendor=05e3,
idProduct=0608
[ 13.740417] usb 1-1: New USB device strings: Mfr=0, Product=1,
SerialNumber=0
[ 13.747680] usb 1-1: Product: USB2.0 Hub
[ 13.752838] hub 1-1:1.0: USB hub found
[ 13.757080] hub 1-1:1.0: 4 ports detected
[ 13.856994] mmc0: new SD card at address aaaa
[ 13.861999] mmcblk0: mmc0:aaaa SD02G 1.84 GiB
[ 13.867187] mmcblk0: p1 p2
[ 13.872375] mmcblk0: p2 size 3116610 exceeds device capacity,
limited to end of disk
[ 14.068328] usb 1-1.1: new high speed USB device using ehci-omap
and address 3
[ 14.199066] usb 1-1.1: New USB device found, idVendor=090c,
idProduct=b371
[ 14.206024] usb 1-1.1: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 14.213470] usb 1-1.1: Product: USB 2.0 PC Cam
[ 14.218017] usb 1-1.1: Manufacturer: Image Processor
[ 14.224548] uvcvideo: Found UVC 1.00 device USB 2.0 PC Cam
(090c:b371)
[ 14.632049] input: USB 2.0 PC Cam as /devices/platform/ehci-omap.0/
usb1/1-1/1-1.1/1-1.1:1.0/input/input2
[ 14.724609] usb 1-1.2: new low speed USB device using ehci-omap and
address 4
[ 14.855438] usb 1-1.2: New USB device found, idVendor=413c,
idProduct=2106
[ 14.862792] usb 1-1.2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 14.870513] usb 1-1.2: Product: Dell QuietKey Keyboard
[ 14.876831] usb 1-1.2: Manufacturer: Dell
[ 14.890472] input: Dell Dell QuietKey Keyboard as /devices/platform/
ehci-omap.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input3
[ 14.903106] generic-usb 0003:413C:2106.0001: input: USB HID v1.10
Keyboard [Dell Dell QuietKey Keyboard] on usb-ehci-omap.0-1.2/input0
[ 14.998077] usb 1-1.3: new low speed USB device using ehci-omap and
address 5
[ 15.127838] usb 1-1.3: New USB device found, idVendor=15ca,
idProduct=00c3
[ 15.134826] usb 1-1.3: New USB device strings: Mfr=0, Product=2,
SerialNumber=0
[ 15.143493] usb 1-1.3: Product: USB Optical Mouse
[ 15.157318] input: USB Optical Mouse as /devices/platform/ehci-omap.
0/usb1/1-1/1-1.3/1-1.3:1.0/input/input4
[ 15.167938] generic-usb 0003:15CA:00C3.0002: input: USB HID v1.10
Mouse [USB Optical Mouse] on usb-ehci-omap.0-1.3/input0
[ 25.493774] EXT3-fs (mmcblk0p2): warning: maximal mount count
reached, running e2fsck is recommended
[ 25.503143] kjournald starting. Commit interval 5 seconds
[ 26.003356] EXT3-fs (mmcblk0p2): using internal journal
[ 26.008697] EXT3-fs (mmcblk0p2): recovery complete
[ 26.016052] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 26.023620] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 26.032226] devtmpfs: mounted
[ 26.035278] Freeing init memory: 184K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
[ 27.134460] udev: starting version 151
Remounting root file system...
udevadm settle - timeout of 3 seconds reached, the event queue
contains:
/sys/devices/platform/ehci-omap.0/usb1/1-0:1.0 (634)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.1/1-1.1:1.0 (637)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.1/1-1.1:1.0/input/
input2 (638)
input2/event2 (639)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.1/1-1.1:1.1 (640)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.2/1-1.2:1.0 (643)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:
2106.0001 (644)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.2/1-1.2:1.0/input/
input3 (645)
input3/event3 (646)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.3/1-1.3:1.0 (649)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:15CA:
00C3.0002 (650)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1.3/1-1.3:1.0/input/
input4 (651)
input4/event4 (652)
input4/mouse0 (653)
/sys/devices/platform/ehci-omap.0/usb1/1-1/1-1:1.0 (655)
/sys/devices/platform/gpio-keys/input/input0 (659)
/sys/devices/platform/gpio-keys/input/input0/event0 (660)
/sys/devices/platform/i2c_omap.1/i2c-1/1-0048 (662)
/sys/devices/platform/i2c_omap.1/i2c-1/1-0049 (663)
/sys/devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_gpio/gpio/
gpiochip192 (664)
/sys/devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_pwrbutton/
input/input1 (665)
input/input1/event1 (666)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004a (667)
/sys/devices/[ 31.099273] end_request: I/O error, dev mtdblock2,
sector 0
[ 31.107025] Buffer I/O error on device mtdblock2, logical block 0
platform/i2c_omap.1/i2c-1/1-004b (668)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.17/regulator/
regulator.0 (669)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.18/regulator/
regulator.1 (670)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.19/regulator/
regulator.2 (671)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.3/regulator/
regulator.4 (672)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.5/regulator/
regulator.5 (673)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.6/regulator/
regulator.3 (674)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_reg.8/regulator/
regulator.6 (675)
/sys/devices/platform/i2c_omap.1/i2c-1/1-004b/twl_rtc/rtc/rtc0 (676)
/sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa (686)
/sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/
mmcblk0 (687)
mmcblk0/mmcblk0p1 (688)
mmcblk0/mmcblk0p2 (689)
/sys/devices/virtual/block/loop0 (728)
/sys/devices/virtual/block/loop1 (729)
/sys/devices/virtual/block/loop2 (730)
/sys/devices/virtual/block/loop3 (731)
/sys/devices/virtual/block/loop4 (732)
/sys/devices/virtual/block/loop5 (733)
/sys/devices/virtual/block/loop6 (734)
/sys/devices/virtual/block/loop7 (735)
/sys/devices/virtual/block/ram0 (736)
/sys/devices/virtual/block/ram1 (737)
/sys/devices/virtual/block/ram10 (738)
/sys/devices/virtual/block/ram11 (739)
/sys/devices/virtual/block/ram12 (740)
/sys/devices/virtual/block/ram13 (741)
/sys/devices/virtual/block/ram14 (742)
/sys/devices/virtual/block/ram15 (743)
/sys/devices/virtual/block/ram2 (744)
/sys/devices/virtual/block/ram3 (745)
/sys/devices/virtual/block/ram4 (746)
/sys/devices/virtual/block/ram5 (747)
/sys/devices/virtual/block/ram6 (748)
/sys/devices/virtual/block/ram7 (749)
/sys/devices/virtual/block/ram8 (750)
/sys/devices/virtual/block/ram9 (751)
[ 31.741363] end_request: I/O error, dev mtdblock2, sector 0
[ 31.747009] Buffer I/O error on device mtdblock2, logical block 0
[ 31.774505] end_request: I/O error, dev mtdblock2, sector 0
[ 31.780120] Buffer I/O error on device mtdblock2, logical block 0
[ 31.795257] end_request: I/O error, dev mtdblock2, sector 0
[ 31.800872] Buffer I/O error on device mtdblock2, logical block 0
[ 31.807434] end_request: I/O error, dev mtdblock2, sector 0
[ 31.813049] Buffer I/O error on device mtdblock2, logical block 0
[ 31.819793] end_request: I/O error, dev mtdblock2, sector 0
[ 31.825408] Buffer I/O error on device mtdblock2, logical block 0
[ 31.832244] end_request: I/O error, dev mtdblock2, sector 0
[ 31.837860] Buffer I/O error on device mtdblock2, logical block 0
[ 31.845001] end_request: I/O error, dev mtdblock2, sector 0
[ 31.850616] Buffer I/O error on device mtdblock2, logical block 0
[ 31.857391] end_request: I/O error, dev mtdblock2, sector 0
[ 31.863037] Buffer I/O error on device mtdblock2, logical block 0
[ 31.869506] end_request: I/O error, dev mtdblock2, sector 0
[ 31.875122] Buffer I/O error on device mtdblock2, logical block 0
[ 31.881835] end_request: I/O error, dev mtdblock2, sector 0
[ 31.887756] end_request: I/O error, dev mtdblock2, sector 0
[ 31.893920] end_request: I/O error, dev mtdblock2, sector 0
[ 31.899902] end_request: I/O error, dev mtdblock2, sector 0
[ 31.906036] end_request: I/O error, dev mtdblock2, sector 0
[ 31.912017] end_request: I/O error, dev mtdblock2, sector 0
[ 31.918151] end_request: I/O error, dev mtdblock2, sector 0
[ 31.924102] end_request: I/O error, dev mtdblock2, sector 0
[ 31.930053] end_request: I/O error, dev mtdblock2, sector 0
[ 31.936309] end_request: I/O error, dev mtdblock2, sector 0
[ 31.942199] end_request: I/O error, dev mtdblock2, sector 0
[ 31.948150] end_request: I/O error, dev mtdblock2, sector 0
[ 31.954101] end_request: I/O error, dev mtdblock2, sector 0
[ 31.960052] end_request: I/O error, dev mtdblock2, sector 0
[ 31.965911] end_request: I/O error, dev mtdblock2, sector 0
[ 32.420928] uvcvideo: module is already loaded
[ 35.708679] end_request: I/O error, dev mtdblock2, sector 0
[ 35.982086] end_request: I/O error, dev mtdblock2, sector 0
[ 36.271148] quiet_error: 47 callbacks suppressed
Caching udev devnodes
Populating dev cachemv: cannot stat `/tmp/uname': No such file or
directory
[ 40.673919] end_request: I/O error, dev mtdblock2, sector 0
[ 40.679534] Buffer I/O error on device mtdblock2, logical block 0
[ 40.714813] end_request: I/O error, dev mtdblock2, sector 0
[ 40.720428] Buffer I/O error on device mtdblock2, logical block 0
[ 40.726928] end_request: I/O error, dev mtdblock2, sector 0
[ 40.732543] Buffer I/O error on device mtdblock2, logical block 0
[ 41.488433] Bluetooth: Core ver 2.15
[ 41.495910] NET: Registered protocol family 31
[ 41.500915] Bluetooth: HCI device and connection manager
initialized
[ 41.507354] Bluetooth: HCI socket layer initialized
[ 41.579467] Bluetooth: L2CAP ver 2.14
[ 41.583160] Bluetooth: L2CAP socket layer initialized
[ 41.615051] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 41.825500] NET: Registered protocol family 10
[ 42.458587] NET: Registered protocol family 23
[ 42.491149] IrCOMM protocol (Dag Brattli)
[ 42.687103] Bluetooth: RFCOMM TTY layer initialized
[ 42.692047] Bluetooth: RFCOMM socket layer initialized
[ 42.697418] Bluetooth: RFCOMM ver 1.11
Unknown HZ value! (47) Assume 100.
ALSA: Restoring mixer settings...
Configuring network interfaces... done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Thu Mar 18 15:17:00 GMT 2010
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Configuring leds:
beagleboard::pmu_stat: none
beagleboard::usr0: heartbeat
beagleboard::usr1: mmc0
Starting Dropbear SSH server: dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Network connection manager daemon: NetworkManager.
Loading kernel modules for gstreamer-ti... [ 48.015686] CMEMK
module: built on Mar 18 2010 at 13:19:12
[ 48.030883] Reference Linux version 2.6.32
[ 48.036376] File /OE/angstrom-dev/work/beagleboard-angstrom-linux-
gnueabi/ti-linuxutils-1_2_25_01_06-r67c/linuxutils_2_25_01_06/packages/
ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 48.067535] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 48.078186] CMEM phys_start (0x86300000) overlaps kernel
(0x80000000 -> 0x90000000)
[ 48.092102] CMEMK Error: Failed to request_mem_region(0x86300000,
16777216)
FATAL: Error inserting cmemk (/lib/modules/2.6.32/kernel/drivers/dsp/
cmemk.ko): Bad address
[ 48.260192] DSPLINK Module (1.64) created on Date: Mar 18 2010
Time: 13:22:42
[ 48.439727] SDMAK module: built on Mar 18 2010 at 13:19:31
[ 48.445800] Reference Linux version 2.6.32
[ 48.450103] File /OE/angstrom-dev/work/beagleboard-angstrom-linux-
ti/sdo/linuxutils/sdma/src/module/sdmak.c
done
Starting PVR
[ 49.341552] PVRSRV_PIXEL_FORMAT_ARGB8888
Loading [g_cdc]
[ 50.222412] g_cdc gadget: using random self ethernet address
[ 50.228698] g_cdc gadget: using random host ethernet address
[ 50.247192] usb0: MAC ce:cd:38:79:2c:5d
[ 50.256042] usb0: HOST MAC ca:98:c3:8e:57:44
[ 50.291473] g_cdc gadget: CDC Composite Gadget, version: King
Kamehameha Day 2008
[ 50.309967] g_cdc gadget: g_cdc ready
[ 50.320220] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 50.337982] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 2
[ 50.353179] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 50.360565] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 50.368164] usb usb2: Product: MUSB HDRC host driver
[ 50.373443] usb usb2: Manufacturer: Linux 2.6.32 musb-hcd
[ 50.378906] usb usb2: SerialNumber: musb_hdrc
[ 50.387451] hub 2-0:1.0: USB hub found
[ 50.399719] hub 2-0:1.0: 1 port detected
Starting GPE display manager: gpe-dm
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-test-20100104 beagleboard ttyS2
