How to transfer files from my PC into RAM of the Beaglebone?
I did it before on Beagleboard but forgot as it was long time ago and
I was using SSH as well.
Now I use WinSCP and want to transfer *.C sources, build them locally
on the Beaglebone and test.
I don't want to copy to SD card for now.
just copy them to /var/volatile, it's tmpfs partition (volatile)
located in RAM, after a reboot the files will disappear.
Don't forget that you RAM has a size limit of 256MB !
You can also put you *.c files on a nfs share and build them remotely
from the BB without any need to transfer them and of course you won't
have a size limit
It works fine.
I noticed that there is a preference of using JavaScript or Python
over C/C++
for a Beaglebone. I am not able to find some basic C examples,
helpfull for beginners.
What is the explanation for that shift?
Thanks again.
The first option works for me with a limitation of 256MB of RAM,
so I attempted to setup an nfs share, so far with no luck.
Can you point me some instruction of how to setup an nfs client on
Beaglebone (Android distro)
and an nfs server on PC (both linux and Win7)?
