I need it as lean as possible. What’s the best way to trim the fat off this system?
The best way would be to start with the minimal image and the install required packages.
It is far easier to add than to remove.
Thanks. Which image is that? Will it flash to eMMC?
The latest images can be found here
Look for a minimal arm64 version.
I think possibly here if you want to flash the emmc, get the emmc flasher version, or you could try a non emmc flasher version on SD card first.
Thanks for the heads up. It works as you said.
