Trouble building a configfs for HID device on BBBW
I am trying to get a BBBW to register itself as a pure HID device.
I’m starting with a modified version of Phil Polstra’s bash script presented at DEF CON (attached). His script was built originally for Ubuntu, but I’m running the latest 9.1 Debian image.
I have updated the original last line from echoing ‘musb-hdrc.0.auto’ to ‘musb-hdrc.0’ (for versions 4.9.x, which mine is).
Here’s what happens:
debian@beaglebone:~$ sudo bash create-hid-BB.sh
create-hid-BB.sh: line 44: echo: write error: Device or resource busy
create-hid-BB.sh: line 29: echo: write error: Device or resource busy
create-hid-BB.sh: line 30: echo: write error: Device or resource busy
create-hid-BB.sh: line 31: echo: write error: Device or resource busy
cp: error writing ‘/sys/kernel/config/usb_gadget/kb/functions/hid.usb0/report_desc’: Device or resource busy
ln: failed to create symbolic link ‘/sys/kernel/config/usb_gadget/kb/configs/c.1/hid.usb0’: File exists
I also tried:
  1. Restarting the system.
  2. Leaving g_multi in place.
  3. Building a kb folder in another folder with the customizations specified in the attached script.
  4. Copying the kb folder to /sys/kernel/config/usb_gadget/
  5. This also fails with the same messages. It’s almost like the moment there’s a /sys/kernel/config/usb_gadget/kb folder, the system connects to it and starts using it. (Note that during this time, my computer is NOT registering the BBBW as a HID device yet).
    It seems like it shouldn’t be this difficult. How can I make a BBBW pure HID?
create-hid-BB.sh (1.38 KB)
add the -ex options to bash, so you can actually watch and therefore
trace what happens..
The first time:
debian@beaglebone:~$ sudo bash -ex create-hid-BB.sh
[sudo] password for debian:
  • grep g_multi
  • lsmod
  • mount
  • grep /sys/kernel/config
  • umount /sys/kernel/config
  • mount none -t configfs /sys/kernel/config
  • kbdir=/sys/kernel/config/usb_gadget/kb
  • ‘[’ ‘!’ -d /sys/kernel/config/usb_gadget/kb ‘]’
  • mkdir /sys/kernel/config/usb_gadget/kb
  • echo 0x1337
  • echo 0x1337
  • echo 0x0100
  • echo 0x0110
  • ‘[’ ‘!’ -d /sys/kernel/config/usb_gadget/kb/configs/c.1 ‘]’
  • mkdir /sys/kernel/config/usb_gadget/kb/configs/c.1
  • echo 500
  • ‘[’ ‘!’ -d /sys/kernel/config/usb_gadget/kb/functions/hid.usb0 ‘]’
  • mkdir /sys/kernel/config/usb_gadget/kb/functions/hid.usb0
  • echo 1
  • echo 1
  • echo 8
  • cp report_descriptor_kb.bin /sys/kernel/config/usb_gadget/kb/functions/hid.usb0/report_desc
  • ln -s /sys/kernel/config/usb_gadget/kb/functions/hid.usb0 /sys/kernel/config/usb_gadget/kb/configs/c.1
  • ‘[’ -d /sys/class/udc/musb-hdrc.0.auto ‘]’
  • ‘[’ -d /sys/class/udc/musb-hdrc.0 ‘]’
  • echo musb-hdrc.0
Same command again:
  • lsmod
  • grep g_multi
  • mount
  • echo 0x1337
  • echo 0x1337
  • echo 0x0100
  • echo 0x0110
  • echo 500
  • echo 1
Did you ever get an answer for this. I followed the directions at: https://wiki.tizen.org/USB/Linux_USB_Layers/Configfs_Composite_Gadget/Usage_eq._to_g_hid.ko
And am now bumping into the same problem:
root@beaglebone:/home/debian/cfg/usb_gadget/g1# pwd
root@beaglebone:/home/debian/cfg/usb_gadget/g1# ls
bcdDevice bcdUSB bDeviceClass bDeviceProtocol bDeviceSubClass bMaxPacketSize0 configs functions idProduct idVendor os_desc strings UDC
root@beaglebone:/home/debian/cfg/usb_gadget/g1# ls -al /sys/class/udc
total 0
drwxr-xr-x 2 root root 0 Jan 16 09:30 .
drwxr-xr-x 58 root root 0 Jan 16 09:30 …
lrwxrwxrwx 1 root root 0 Jan 16 09:29 musb-hdrc.0.auto → …/…/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/udc/musb-hdrc.0.auto
root@beaglebone:/home/debian/cfg/usb_gadget/g1# echo musb-hdrc.0.auto > UDC
-su: echo: write error: Device or resource busy
root@beaglebone:/home/debian/cfg/usb_gadget/g1# echo musb-hdrc.0 > UDC
-su: echo: write error: No such device
root@beaglebone:/home/debian/cfg/usb_gadget/g1# uname -r
4.4.91-ti-r133
Were you able to solve this issue? I am getting the same “Device or resource busy” message.
Thank you.
Were you able to solve this problem? I am facing the same issue here.
Thank you.
Andrei
