I am trying to enable the i2c-2 bus in mainline uBoot and having problems. I am building a cape that has a Trusted Platform Module (TPM) on pins P9_19/20, i2c-2. Using some creative wiring, when I connect the cape to i2c-1, everything works fine.
I added this in /board/ti/am225x/mux.c:
static struct module_pin_mux i2c2_pin_mux[] = {
{OFFSET(uart1_ctsn), (MODE(3) | RXACTIVE |
PULLUDEN | SLEWCTRL)}, /* I2C_DATA /
{OFFSET(uart1_rtsn), (MODE(3) | RXACTIVE |
PULLUDEN | SLEWCTRL)}, / I2C_SCLK */
{-1},
In enable_board_pin_mux, I put the following before any of the ifs:
configure_module_pin_mux(i2c2_pin_mux);
and added a puts after to ensure it was getting hit.
When I break in uboot and try to switch to i2c-2, the BBB resets as follows:
U-Boot# i2c dev 2
Setting bus to 2
data abort
pc : [<9f7745c4>] lr : [<9f7745bc>]
sp : 9f637dc0 ip : 00000000 fp : 9f638598
r10: 9f7a7680 r9 : 9f637f28 r8 : 000186a0
r7 : 00000001 r6 : 9f7a47d4 r5 : 000186a0 r4 : 00000001
r3 : 0000002c r2 : 00000001 r1 : 00000002 r0 : 4819c000
Flags: nZCv IRQs off FIQs on Mode SVC_32
Resetting CPU …
I’m not quite sure where to go from here. It appears, to me, that uBoot has an issue with i2c-2 and any help would be appreciated. I could switch the TPM over to i2c-1 but I’d rather not change the hardware unless using i2c-2 is impossible for some reason in uBoot.
I have a rev B BeagleBone Black BTW.
Josh
