Trouble while building x11-image or console-image with bad checksum
      I'm getting the following error every time I bitbake x11-image
and console-image, it seems that there is a MD5SUM mismatch for gdbm-
native:
NOTE: Running task 70 of 121 (ID: 2, /stuff/openembedded/recipes/gdbm/
gdbm-native_1.8.3.bb, do_fetch)
NOTE: The MD5Sums did not match. Wanted:
'1d1b1d5c0245b1c00aff92da751e9aa1' and Got:
'd41d8cd98f00b204e9800998ecf8427e'
NOTE: Task failed: Checksum of 'ftp://ftp.gnu.org/gnu/gdbm/
gdbm-1.8.3.tar.gz' failed
ERROR: TaskFailed event exception, aborting
ERROR: Build of /stuff/openembedded/recipes/gdbm/gdbm-native_1.8.3.bb
do_fetch failed
ERROR: Task 2 (/stuff/openembedded/recipes/gdbm/gdbm-native_1.8.3.bb,
do_fetch) failed
NOTE: Tasks Summary: Attempted 69 tasks of which 69 didn't need to be
rerun and 1 failed.
ERROR: '/stuff/openembedded/recipes/gdbm/gdbm-native_1.8.3.bb' failed
          But, I've downloaded the file and checked with md5sum and
the checksum is the one expected, for some reason bitbake is obtaining
a wrong checksum:
catilo@catilo-desktop:/stuff/build$ md5sum /home/catilo/Desktop/test/
gdbm-1.8.3.tar.gz
1d1b1d5c0245b1c00aff92da751e9aa1 /home/catilo/Desktop/test/
gdbm-1.8.3.tar.gz
         I've seen in this mail list a previous similar problem where
the reason was that the hard disk partition had a problem, and the
solution was to build in other disk partition. Unfortunately I can't
follow this approach without buying a new disk, so I would like to
find another solution.
       Also, I'm not using any firewall and my hard disk is almost
new.
       I'll appreciate your help!
Alex.
native:
a wrong checksum:[...]
did you try to copy the file you downloaded in
/home/catilo/Desktop/test to where bitbake downloads the source
packages? or just remove the file and let bitbake download it again
there are many other reasons why a package may be different from what
expected: onetime download issues are way more common than hard disk
failures, and are simply solved by downloading the file a second time.
Hi Elena,
Thanks for the advise!. I realized that the problem was a damage instance of gdbm-native .tgz file in my bitbake sources repository, as you mentioned. I fixed the problem by deleting this damaged file and allowing bitbake to download it again.
Alex.
