Hi. First of all, thanks in advance for those who try to help me.
I’m studying about Device Trees, and I’ve chosen to use Beaglebone Green Wireless as a board to practice.
I’ve done the following steps:
- From u-boot serial, I’ve seen that Beaglebone green Wireless is using uses am335x-bonegreen-wireless-uboot-univ.dtb as DTB file
- Cloned / downloaded beaglebone Kernel (from GitHub - beagleboard/linux: The official Read Only BeagleBoard and BeagleBone kernel repository https://git.beagleboard.org/beagleboard/linux)
- I want to add LED at GPIO 47 ( = GPIO1_16, and accordingly to board schematic, AM33xx GPMC_A0 pin). I’ve edited am335x-bone-common.dtsi file, adding led (led6) in leds node as follows:
leds {
pinctrl-names = “default”;
pinctrl-0 = <&user_leds_s0>;
compatible = “gpio-leds”;
led2 {
label = “beaglebone:green:usr0”;
gpios = <&gpio1 21 GPIO_ACTIVE_HIGH>;
linux,default-trigger = “heartbeat”;
default-state = “off”;
led3 {
label = “beaglebone:green:usr1”;
gpios = <&gpio1 22 GPIO_ACTIVE_HIGH>;
linux,default-trigger = “mmc0”;
led4 {
label = “beaglebone:green:usr2”;
gpios = <&gpio1 23 GPIO_ACTIVE_HIGH>;
linux,default-trigger = “cpu0”;
led5 {
label = “beaglebone:green:usr3”;
gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>;
linux,default-trigger = “mmc1”;
led6 {
label = “beaglebone:green:extLed”;
gpios = <&gpio1 16 GPIO_ACTIVE_HIGH>;
And I’ve added gpio2_16 in pinmux of user leds, as follows:
&am33xx_pinmux {
user_leds_s0: user_leds_s0 {
pinctrl-single,pins = <
AM33XX_PADCONF(AM335X_PIN_GPMC_A5, PIN_OUTPUT_PULLDOWN, MUX_MODE7) /* gpmc_a5.gpio1_21 /
AM33XX_PADCONF(AM335X_PIN_GPMC_A6, PIN_OUTPUT_PULLUP, MUX_MODE7) / gpmc_a6.gpio1_22 /
AM33XX_PADCONF(AM335X_PIN_GPMC_A7, PIN_OUTPUT_PULLDOWN, MUX_MODE7) / gpmc_a7.gpio1_23 /
AM33XX_PADCONF(AM335X_PIN_GPMC_A8, PIN_OUTPUT_PULLUP, MUX_MODE7) / gpmc_a8.gpio1_24 /
AM33XX_PADCONF(AM335X_PIN_GPMC_A0, PIN_OUTPUT_PULLUP, MUX_MODE7) / gpmc_a0.gpio1_16 */
- I’ve successfully compiled all dtbs by doing:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- dtbs
After that, I’ve updated the recently compiled am335x-bonegreen-wireless-uboot-univ.dtb file to /boot/dtbs/{uname-r} folder in Beaglebone Green
And, finally, I rebooted the board. However, board has entered in a “strange state”, with all user leds powered on. Using U-Boot serial, I’ve noticed that boot process have stopped at “starting kernel” message
In this case, what have I done wrong? Are my modifications in DTS file right?
Again, thanks in advance.
