I’m trying to build a 3.8.13 kernel with the BBG patches from http://www.seeedstudio.com/recipe/373-how-to-compile-beaglebone-green-linux-kernel.html.
I hit this error during the build:
make[1]: Leaving directory /home/keithconger/Projects/bbbandroid-bluez/kernel' make -C kernel ARCH=arm CROSS_COMPILE=/home/keithconger/Projects/bbbandroid-bluez/prebuilts/gcc/linux-x86/arm/arm-gnueabihf-4.7/bin/arm-linux-gnueabihf- dtbs make[1]: Entering directory
/home/keithconger/Projects/bbbandroid-bluez/kernel’
DTC arch/arm/boot/dts/am335x-bone.dtb
DTC arch/arm/boot/dts/am335x-boneblack.dtb
DTC arch/arm/boot/dts/am335x-bonegreen.dtb
Error: arch/arm/boot/dts/am335x-bonegreen.dts:45.15-16 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [arch/arm/boot/dts/am335x-bonegreen.dtb] Error 1
make[2]: *** Waiting for unfinished jobs…
make[1]: *** [dtbs] Error 2
make[1]: Leaving directory `/home/keithconger/Projects/bbbandroid-bluez/kernel’
make: *** [kernel_build] Error 2
Line 45 and 46 are:
0x150 (PIN_INPUT | MUX_MODE1) /* spi0_sclk.uart2_rxd */
0x154 (PIN_OUTPUT | MUX_MODE1) /* spi0_d0.uart2_txd */
Anyone know how to resolve this?
Your problem is very likely that you do not have the files
#include “am33xx.dtsi”
#include “am335x-bone-common.dtsi”
In your path. I get the same error here:
$ dtc -O dtb -o am335x-bonegreen.dtbo -b 0 -@ am335x-bonegreen.dts
Error: am335x-bonegreen.dts:10.1-9 syntax error
So, you missed a step somewhere. Which kernel version will the target be using ? This should be trivial to fix, but the only option I can think of offhand is git cloning https://github.com/RobertCNelson/device-tree-rebasing, and then placing your bonegreen dts file into the /src/arm/ directory, and compiling manually. As I have no idea which instructions you are following, and what the steps are.
OR
Perhaps placing am33xx.dtsi and am335x-bone-common.dtsi in the same directory as am335x-bonegreen.dts, and try again. I’ve never done this personally, but it should work. In fact, I think it makes more sense than the first option I mention above. With one caveat: I do not recall if either of these include files have further dependencies in this git tree.
One additional note: That git has the bonegreen dts file in it already. So git cloning that git, and running dtc in the src/arm/ directory for that file should just work.
Following these line of reasoning, I get the same error. hmmm give me a minute.
strace output
http://pastebin.com/8ype90wD
I’m looking into it.
Well I was attempting to create a *.dtbo file from the source, but here this works:
$ git clone https://github.com/RobertCNelson/dtb-rebuilder.git
Cloning into ‘dtb-rebuilder’…
remote: Counting objects: 6357, done.
remote: Compressing objects: 100% (12/12), done.
remote: Total 6357 (delta 3), reused 0 (delta 0), pack-reused 6343
Receiving objects: 100% (6357/6357), 4.38 MiB | 344 KiB/s, done.
Resolving deltas: 100% (2563/2563), done.
$ cd dtb-rebuilder/
$ make src/arm/am335x-bonegreen.dtb
DTC src/arm/am335x-bonegreen.dtb
$ cp src/arm/am335x-bonegreen.dtb .
$ ls
Bindings COPYING Makefile README am335x-bonegreen.dtb dtc-overlay.sh include scripts src
Doh, I just realized you’re working with a 3.8.x kernel . . . These instructions above I believe will only work with 4.x, as that’s what the sourced in this repo are meant for. However, I bet the device tree source files are exactly the same. But unsure if dt-bindings are different or not.
OK, wow those instructions are whack. First of all this is the proper way to use Robert’s bb-kernel repo:
https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-LinuxKernel
Secondly, this builds all the necessary BBG files as well( as far as I know ). So in short . . .
$ git clone https://github.com/RobertCNelson/bb-kernel
$ cd bb-kernel/
$ git checkout origin/am33x-v3.8 -b tmp
Now you can build with:
$ ./build_kernel.sh
OR
$ ./build_deb.sh
build_deb.sh will build a Debian package, that will allow you to install this new kernel over the top of an existing kernel( and including dependencies ) on an already working image. Extremely useful if you need to make kernel tweaks only to a system.
I am curious though. Any specific reason why you have to use a 3.8.x kernel ? the 4.x kernels are pretty good now days . . .and they seem to be noticeably faster too.
Hi William,
Thanks for looking at this for me.
I’m using 3.8 for video acceleration and Android. I have not been able to get more recent kernels to fully work with everything I need on BBB.
I copied the dts file from the am33x-v3.8 tree into my kernel and was able to build and boot the kernel. Now I’m trying to get the 4D LCD4 cape functioning.
Keith
Is that even possible ? With the HDMI framer not even existing on the BBG?
External video capes such as the lcd work fine with the BBG..
It's just missing the am335x_lcd_pins -> Nxp lcd-hdmi framer -> hdmi connector..
I’ve got my LCD working but I’m struggling with enabling UART2 with it connected.
I’m getting a conflict between the two:
[ 1.749303] bone-capemgr bone_capemgr.9: slot #5: BB-UART2 conflict P9.21 (#3:BB-BONE-LCD4-01)
What’s weird is the LCD’s datasheet doesn’t show that pin being used.
http://www.4dsystems.com.au/productpages/4DCAPE-43/downloads/4DCAPE-43(T)_datasheet_R_1_9.pdf
Anyone come across this before?
Keith
I’m using 3.8.13. In the kernel source I’m using BB-BONE-LCD4-01-00A1.dts does have that pin being used. I just found the article below. So I’ve removed the offending lines and I’m creating a new image to test.
https://accustrata.wordpress.com/2014/10/27/lcd4-cape-and-circuitco-adc-cape-working-together/
Keith
Ah, figures. Sorry, should of confirmed I was using the latest.
Thanks again,
Keith
Shouldn’t git checkout origin/am33x-v3.8 -b tmp have pulled the latest sources ?
That is what's odd, he got a branch from over a year ago.. "git
checkout origin/xyz -b tmp" just creates a branch on the local value
of 'xyz', so without a 'git pull' before hand...
Yet still, a repo from over a year ago..
That is what’s odd, he got a branch from over a year ago… "git
of ‘xyz’, so without a ‘git pull’ before hand…
Yet still, a repo from over a year ago…
I blame those whack seed “instructions” . . .heh. Never ceases to amaze though how people can take something perfectly good, then feel compelled to make it “better” .
It did but I manually copied in what I thought I needed. The kernel I’m using has a few additional patches applied. So. I went the quick and dirty route.
Over the next two weeks I may try to get a newer kernel built. Does anyone know what the newest kernel with sgx support is? Is it still 3.14?
Keith
