Trying to build tlv430
I have been lurking about these boards asking a few questions about beaglebone. Off and on when I have time I am evaluating the beaglebone for a low latency audio application.
I am using the 4.4.20-ti-r44 build at the moment, in a previous post I have swapped using RPMsg for the older uio_pruss library which was more flexible for my needs. Thanks to a lot of help on the board I managed to get the PRUs loaded and running.
The next thing I want to try is to get the TLV320AIC3204 codec working with the beaglebone black. Looking at the forums there is a lot to do.
  1. Build a kernel module driver, install on target machine under /lib/modules/(kernel name)/kernel/sound.soc.codecs
  2. Look at the dts and disable hdmi support
  3. Then start adding alsa support into the dts for pins, i2c config, links to alsa , etc.
Unfortunately I am stuck at 1 8-(. Being a newbie I am not quie sure what to do.
It looks like there is a driver for it:
KERNEL/sound/soc/codecs/tlv320aic32x4.c
The current kernel has support for snd-soc-tlv320aic31xx.ko, and snd-soc-tlv320aic32032x4.ko. I want to add snd-soc-tlv320aic32x4.ko,
So I cloned the bb kernel. git clone https://github.com/RobertCNelson/bb-kernel , and tried to build ./build_kernel I hoped I could run make menuconfig and enable it but it is not an option.
So some question if anyone can help.
  1. There is no branch for 4.4.20-ti-r44 so I am a bit confused. It might be obvious to guys with experience why but I don;t understand, am I looking at the wrong repository. It looks like this repository is the main one for beaglebone.
  2. So I went for the current release branch at 4.4 just to get started. Started the build and when the menu config came up there was no option to select tlv320aic32032x4. So I looked at the Kconfig , and makefile in the /sound.soc/codecs directory and the file exists, there is an option in the makefile to build if the config is selected. The KConfig looks like it is not selected. I tried to add an option in Kconfig and rebuild using ./build_kernel but it looks like it overwrites my Kconfig when it patches the bbb patch onto 4.4.
  3. Can anyone help, Is there a way just to build the code without calling the patch update ? Also can I add the configuration option into the menu,
I know this is probably basic.
Thanks for any replies,
Paul
loaded and running.
1) Build a kernel module driver, install on target machine under
2) Look at the dts and disable hdmi support
3) Then start adding alsa support into the dts for pins, i2c config, links
to alsa , etc.
do.
GitHub - RobertCNelson/bb-kernel , and tried to build
is not an option.
1) There is no branch for 4.4.20-ti-r44 so I am a bit confused. It might be
beaglebone.
4.4.20-ti-r44 was generated from:
but don't use it, as "old tags" can't be used in that repo, instead
grab yakbuild and follow the readme/recipe example
2) So I went for the current release branch at 4.4 just to get started.
if you make changes under ./KERNEL/
run:
./tools/rebuild.sh
3) Can anyone help, Is there a way just to build the code without calling
Thanks for the reply Robert. I can build the kernel fine. The trouble is when I try to run the rebuild script under tools I get:
/bin/sh: 0: Can’t open /home/proserv/ti-processor-sdk-linux-am335x-evm-03.00.00.04/linux-devkit/yakbuild/tools/tools/host_det.sh
I checked the ownership of the scripts and files and it is proserv (my user)
drwxrwxrwx 2 proserv proserv 4096 Nov 4 13:17 deploy
-rwxrwxrwx 1 proserv proserv 13600 Nov 4 10:53 host_det.sh
-rwxrwxrwx 1 proserv proserv 9593 Nov 4 10:53 install_kernel.sh
-rwxrwxrwx 1 proserv proserv 4994 Nov 4 10:53 local_install.sh
-rwxrwxrwx 1 proserv proserv 4624 Nov 4 10:53 rebuild_deb.sh
-rwxrwxrwx 1 proserv proserv 7038 Nov 4 14:23 rebuild.sh
probably I am being stupid. Can’t see what else is wrong. Would you have any ideas ?
PS also tried bash and dash as well as sh, same problem.
Not a clue..
So let's go over what the readme says:
git clone https://github.com/RobertCNelson/yakbuild
cd ./yakbuild/
cp recipe.sh.sample recipe.sh
change kernel_tag in the "recipe.sh" to "4.4.20-ti-r44"...
run:
./build_kernel.sh
The kernel build works fine, no problem there, I have the correct images build, rebuild_kernel.sh is ok.
Then I have changed the Kconfig in /KERNEL/soc/codecs/ to add below to give an option to enable the tlv320aic32x4 driver through menu config.
‘config SND_SOC_TLV320AIC32X4
tristate “Texas Instruments TLV320AIC3x4 CODECs”
depends on I2C
select SND_SOC_TLV320AIC32x4’
I want to just rebuild the kernel now without calling git checkout to avoid overwriting my change. Sorry if this basic but it is not clear to me how I can rebuild the kernel without going through the git clone, and checkouts again.
So as suggested I try running /rebuild.sh in the tools directory and it says it can’t open any of the other sh files in the directory. I tried dash and bash, I’ve checked the files are executable and all appears ok.
Cheers,
Paul
Oops sorry I mean build_kernel.sh worked fine.
run as:
yakbuild$ ./tools/rebuild.sh
Helps also if I get the right sh in the tools directory… I meant rebuild.sh. It’s been a long day…
Paul,
Have you copied the exact error message you’re getting on the cmd line and pasted it to us yet ? If so, I’m not seeing it . . .
Thanks again, got it, understand now , it should be called from the top level directory. A bit slow … 8-).
