http://elinux.org/BeagleBoardUbuntu#DSP states that I need as a
requirement a Kernel built with: "CONFIG_TIDSPBRIDGE=m" .
How would I got about building and installing TIDSPBRIDGE ???
First check, might be enabled:
voodoo@beagle-xma-512mb:~$ zcat /proc/config.gz | grep TIDSP
CONFIG_TIDSPBRIDGE_MEMPOOL_SIZE=0x600000
# CONFIG_TIDSPBRIDGE_DEBUG is not set
CONFIG_TIDSPBRIDGE_RECOVERY=y
# CONFIG_TIDSPBRIDGE_CACHE_LINE_CHECK is not set
CONFIG_TIDSPBRIDGE_WDT3=y
CONFIG_TIDSPBRIDGE_WDT_TIMEOUT=5
# CONFIG_TIDSPBRIDGE_NTFY_PWRERR is not set
# CONFIG_TIDSPBRIDGE_BACKTRACE is not set
For building linaro's kernel, linaro.org has some hints..
https://wiki.linaro.org/Resources/HowTo/PackageYourOwnKernel
So now this is where things get a little bit hairy. I have recompiled
the kernel following the instructions on the linaro wiki. Using zcat
I am able to confirm that the tidspbridge module has been enabled
including all the above mentioned configurations. I have followed the
steps from the beagle ubuntu wiki on installing dsp utilizing your
scirpt.
dsp-test works, although I am getting an error message to my main
console of procwrap_Detach: deprecated despbridge loctl
Now I've tried to setup ALSA...
supo apt-get instal alsa-base alsa-utils
this installation goes fine (or so it would seem). Until I try and
launch the alsa mixer... when I try
linaro@speaker-bot:~$ alsamixer
cannot open mixer: No such file or directory
just in case it was a permissions error I tried to verify that linaro
was added to the audio group and also tried running command as root
root@speaker-bot:/home/linaro# alsamixer
cat /proc/asound/cards is listing no soundcards as available... so
perhaps there is a step I missed in the setup
So I've made a little bit of progress (I think)
I ran apt-get install oss-compat and now my lsmod looks like this
linaro@speaker-bot:~$ lsmod
Module Size Used by
bridgedriver 183438 0
mailbox_mach 5143 0
mailbox 5788 2 bridgedriver,mailbox_mach
mousedev 10624 0
snd_soc_twl4030 37248 0
snd_soc_core 113794 1 snd_soc_twl4030
snd_pcm_oss 44144 0
snd_mixer_oss 14847 1 snd_pcm_oss
snd_pcm 83041 3
snd_soc_twl4030,snd_soc_core,snd_pcm_oss
snd_timer 20972 1 snd_pcm
snd 67219 5
snd_soc_core,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
snd_page_alloc 5419 1 snd_pcm
although I am still having the problem with alsamixer not working, and
with no list of soundcards...
