Trying to get SGX libs to initialise
I have the drivers and latest libs installed, but still can't get this stuff to run. eglInitialize is failing, and as the lib is closed source I can't find out why. I'm running the latest OE build for Beagleboard (console, no X, tho I installed libx11-6 as it was a dependency).
# cat /proc/version
Linux version 2.6.28-omap1 (rvoisey@shuttle) (gcc version 4.2.1) #1 Mon Feb 2 17:56:09 GMT 2009
# cat /proc/cmdline
console=ttyS2,115200n8 root=/dev/mmcblk0p2 rootdelay=2 rootfstype=ext3 video=omapfb:vram:4M omapfb.video_mode=800x600MR-24@60
# ipkg info libgles-omap3
Package: libgles-omap3
Version: 3.00.00.06-r5.1
Depends: update-rc.d, libc6 (>= 2.6.1), libx11-6 (>= 1.1.5)
Recommends: libgles-omap3-tests, omap3-sgx-modules
Status: install user installed
Section: base
Architecture: armv7a
Maintainer: Rob Voisey <rob@pixelbeat.co.uk>
Description: libGLES for the omap3
Installed-Time: 1233976889
Installed-Size: 5664215
# cat /proc/pvr/version
Version 1.3.13.1397 (release) /.../tmp/work/beagleboard-pixelbeat-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r5/omap3-sgx-modules-7
System Version String: SGX revision = 1.0.3
# cat /proc/fb
0 omapfb
1 omapfb
2 omapfb
# cat /proc/pvr/nodes
Registered nodes
Addr Type Class Index Ref pvDev Size Res
c6ffc560 ?8 display 1 1 c7b94e60 48 00000000
c6ffc320 ?7 3D 0 1 c8943000 0 c7ad0bc0
The pre-built demos all fail like this:
# Raw/TrainingCourse/Initialization/OGLES2Initialization
Error: eglInitialize() failed.
I made a very simple test app, and observed that:
eglGetDisplay((EGLNativeDisplayType)EGL_DEFAULT_DISPLAY) returns 1
eglInitialize(eglDisplay, &iMajorVersion, &iMinorVersion) returns EGL_FALSE
Note that I can open /dev/fb0 and run my own graphics routines on it with no problem. I tried *not* doing so but that didn't help. I'm suspicious of the boot arguments and tried a few variants, but admit I'm groping around in the dark.
Thanks for any hints.
Rob
Op 7 feb 2009 om 20:40 heeft "Rob Voisey" <rob@pixelbeat.co.uk> het
volgende geschreven:\
this stuff
can't
(console, no
# cat /proc/version
Mon Feb
2 17:56:09 GMT 2009
# cat /proc/cmdline
Change that to mr-16, sgx doesn't support 32bit.
Koen
Koen
Thanks, that did get me further. The call to eglInitialize no longer fails, and a call to eglChooseConfig also succeeds, however eglCreateWindowSurface then fails with EGL_NOT_INITIALIZED. I'm using the config attributes from the lib examples:
EGL_SURFACE_TYPE = EGL_WINDOW_BIT
EGL_RENDERABLE_TYPE = EGL_OPENGL_ES2_BIT
EGL_CONTEXT_CLIENT_VERSION = 2
I remember why I hate closed source libraries now!
Rob
Rob,
Where you got the SGX lib? Could you share with me?
Yi
You need to contact TI to get the libraries.
Rob
A bit more info:
The following tests execute without error:
sgx_init_test
sgx_blit_test
sgx_render_test
The following tests fail:
sgx_flip_test FAIL - PVRSRV_ERROR_TOOMANYBUFFERS
sgx_render_flip_test FAIL - PVRSRV_ERROR_TOOMANYBUFFERS(27)
All EGL/OGLES tests fail with code 3001, which I believe is
EGL_NOT_INITIALIZED, raised during eglCreateWindowSurface.
I've attached some output.
I'll have a dig into that kernel module error tomorrow, but if anyone has
any ideas I'd love to hear them.
Rob
eglinfo.txt (1.41 KB)
sgx_blit_test.txt (2.71 KB)
sgx_flip_test.txt (2.01 KB)
sgx_init_test.txt (2.34 KB)
sgx_render_flip_test.txt (1.94 KB)
sgx_render_test.txt (2.37 KB)
Could you give me the contact email address? Thanks a lot.
Yi
A bit more info:
sgx_init_test
sgx_blit_test
sgx_render_test
You could try increasing the VRAM a bit in DSS2, that might help.
regards,
Koen
I went via the UK distributor, but the TI website offers this address:
gamingonomap@list.ti.com
http://focus.ti.com/general/docs/wtbu/wtbugencontent.tsp?templateId=6123&navigationId=12700&contentId=27458
Rob
Thanks, that didn't solve the problem. However TI suggested adding:
[default]
WindowSystem=libpvrPVR2D_FRONTWSEGL.so
to powervi.ini and this did work around the problem. At last I can get on with some graphics development which is great news.
Rob
Ah right, the default is FLIP, which has no kernel support anymore.
regards,
Koen
Rob,
[default]
That's great news. Does that mean that you can now run the 3D demos?
Please forgive my ignorance, but where is this .ini file to be found?
I have run a "find / -name p*.ini" on my Beagle and it came up with a
couple of ini files, neither of which is this one.
Yes. Some of them are quite pretty.
The ini file doesn't exist with the current distribution. Create it yourself: /etc/powervr.ini
Don't forget you must also run with a 16-bit framebuffer (which is a showstopper for me unfortunately).
Regards
Rob
Thanks, Rob.
I tried this but it didn't work - running strace showed that it was
still loading the "flip" library. I tried a couple of things, like
putting it in the current directory, to no avail. Perhaps some sort of
formatting issue?
However, you still gave me the vital information I needed.
I ended up copying the "frontwsegl" library I wanted over the "flip"
library. Dreadful, awful, hacky solution but it got me far enough to
run the demos. Now all I have to do is find a way to compile my own
game :slight_smile:
