I have connected a USB modem to my BBB. In looking at the syslog, I see the following:
I am needing to execute a script and specify which ttyUSB* but am a bit confused on knowing which to use.
Sadly it really depends on the modem, there’s really no good one standard for these guys…
Searching based on the vid/pid found:
https://forum.u-blox.com/index.php/22118/sara-r4-usb-interface
Looks like the 2nd port is for AT commands… Do you have any docs on the modem?
Thanks for the response Robert.
I have some guides and tutorials from the site, https://hologram.io/.
I ended up running through each one and in my script and ttyUSB2 was the winner. Which jives with what you found regarding the AT commands.
Thanks!
