Trying to Upload new DTO, "file exists"
Good evening,
I’m trying to setup a new DTO to set pin 8_27 to be in Mode 5. I have a device tree overlay but I can’t load the overlay. I am using the most recent release of Angstrom.
echo bspm_P8_27-d > /sys/devices/bone_capemgr.?/slots
I get an error saying…
-sh: echo: write error: File exists
I presume that it is because the HDMI overlay is still being loaded even though I have already disabled in uEnv.txt. I have seen a hundred ways to implement this and have tried many.
bone_capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
However, when I run check the SLOTS for the device tree it is still listed in there. Here is some things from dmesg when I try to load the DTO to SLOTS.
[ 1467.076411] bone-capemgr bone_capemgr.8: part_number ‘bspm_P8_27_d’, version ‘N/A’
[ 1467.080689] bone-capemgr bone_capemgr.8: slot #8: generic override
[ 1467.080752] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 8
[ 1467.080808] bone-capemgr bone_capemgr.8: slot #8: ‘Override Board Name,00A0,Override Manuf,bspm_P8_27_d’
[ 1467.081072] bone-capemgr bone_capemgr.8: slot #8: Requesting part number/version based 'bspm_P8_27_d-00A0.dtbo
[ 1467.081127] bone-capemgr bone_capemgr.8: slot #8: Requesting firmware ‘bspm_P8_27_d-00A0.dtbo’ for board-name ‘Override Board Name’, version ‘00A0’
[ 1467.081489] bone-capemgr bone_capemgr.8: slot #8: dtbo ‘bspm_P8_27_d-00A0.dtbo’ loaded; converting to live tree
[ 1467.082020] bone-capemgr bone_capemgr.8: slot #8: bspm_P8_27_d conflict P8.27 (#5:BB-BONELT-HDMI)
[ 1467.091610] bone-capemgr bone_capemgr.8: slot #8: Failed verification
I’m fairly certain that this error is due to the HDMI still being enabled and because the pin I wish to use is part of this overlay I can’t load the new overlay as it would be in conflict. Also here is my DTO. I thought maybe modifying the DTO for the HDMI and eliminating the pins that I want may work but I also don’t want to brick the Beaglebone. Still a novice tip toeing around.
  • This is a template-generated file from BoneScript
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
part_number = “BS_PINMODE_P8_27_0xd”;
exclusive-use =
“P8.27”,
“pr1_pru1_pru_r30_8”;
fragment@0 {
target = <&am33xx_pinmux>;
overlay {
bs_pinmode_P8_27_0xd: pinmux_bs_pinmode_P8_27_0xd {
pinctrl-single,pins = <0x0e0 0xd>;
fragment@1 {
target = <&ocp>;
overlay {
bs_pinmode_P8_27_0xd_pinmux {
compatible = “bone-pinmux-helper”;
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <&bs_pinmode_P8_27_0xd>;
Any help is appreciated.
Tyler
