i have made my own custom board based on beaglebone black wireless.
only change in that is my EEPROM is blank. To bypass that check i tried following methods.
- i applied these patches based on this post
https://octavosystems.com/forums/topic/osd3358-boot/#post-4733
– patch -p1 < 0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
– patch -p1 < 0002-U-Boot-BeagleBone-Cape-Manager.patch
– patch -p1 < 0002-NFM-Production-eeprom-assume-device-is-BeagleBone-Bl.patch
it didnt give any result and i havent received anything on serial debug header.
- then hardcoded the function in u-boot/board/ti/am335x/board.h
static inline int board_is_bone_lt(void)
printf(“called it\n”);
return 1;
i received following log on the serial debug…
U-Boot SPL 2018.03-00001-g3751650-dirty (Mar 14 2018 - 19:32:44 +0530)
Trying to boot from MMC1
Loading Environment from FAT… *** Warning - bad CRC, using default environment
Failed (-5)
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called ltU-Boot 2018.03-00001-g3751650-dirty (Mar 14 2018 - 19:32:44 +0530)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Error binding driver ‘gpio_omap’: -22
Some drivers failed to bind
Error binding driver ‘generic_simple_bus’: -22
initcall sequence 9ffac608 failed at call 8080e757 (err=-22)ERROR ### Please RESET the board
it continuously reset the board with these two errors repeatedly.
Failed (-5)
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
Called lt
DRAM: 512 MiB
No serial driver found
Device tree error at node NULL
resetting …
Can you tell me what should i do to boot images like BBBW does. Your little guidance will help me a lot.
Keval Desai
