U-Boot is not compiling (other failure)
I got problems building u-boot, too:
From the logs:
abakus:Linux/bb-kernel-3.15.x>ls -l
total 1143756
drwxr-xr-x 2 auser users 4096 2014-10-06 19:15 DTC
drwxr-xr-x 12 auser users 4096 2014-10-06 20:34 bb-kernel
-rw-r--r-- 1 auser users 1120037232 2014-10-07 05:02 bb-kernel-3.15.x-2014-10-07.tar.7z
drwxr-xr-x 7 auser users 4096 2014-04-16 20:07 gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux
-rw-r--r-- 1 auser users 51126392 2014-04-24 11:07 gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.xz
abakus:Linux/bb-kernel-3.15.x>git clone git://git.denx.de/u-boot.git
Cloning into 'u-boot'...
remote: Counting objects: 277083, done.
remote: Compressing objects: 100% (54903/54903), done.
Receiving objects: 100% (277083/277083), 65.25 MiB | 237.00 KiB/s, done.
remote: Total 277083 (delta 220844), reused 273006 (delta 217018)
Resolving deltas: 100% (220844/220844), done.
Checking connectivity... done.
total 1143756
drwxr-xr-x 22 auser users 4096 2014-10-07 19:27 u-boot
abakus:Linux/bb-kernel-3.15.x>cd u-boot
abakus:bb-kernel-3.15.x/u-boot>git checkout v2014.07 -b tmp
Switched to a new branch 'tmp'
abakus:bb-kernel-3.15.x/u-boot>wget -c https://raw.githubusercontent.com/eewiki/u-boot-patches/master/v2014.07/0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
--2014-10-07 19:28:12-- https://raw.githubusercontent.com/eewiki/u-boot-patches/master/v2014.07/0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
Resolving raw.githubusercontent.com... 185.31.17.133
Connecting to raw.githubusercontent.com|185.31.17.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 10247 (10K) [text/plain]
Saving to: ‘0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch’
100%[====================================================================================================>] 10,247 --.-K/s in 0.04s
2014-10-07 19:28:12 (242 KB/s) - ‘0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch’ saved [10247/10247]
abakus:bb-kernel-3.15.x/u-boot>patch -p1 < 0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
patching file include/configs/am335x_evm.h
abakus:bb-kernel-3.15.x/u-boot>echo ${CC}
/home/auser/data/pools/pool05/BeagleboneBlack/Linux/bb-kernel-3.15.x/gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux/bin/arm-linux-gnueabihf-
abakus:bb-kernel-3.15.x/u-boot>${CC}gcc --version
arm-linux-gnueabihf-gcc (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) 4.8.3 20140401 (prerelease)
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
abakus:bb-kernel-3.15.x/u-boot>make ARCH=arm CROSS_COMPILE=${CC} distclean
abakus:bb-kernel-3.15.x/u-boot>make ARCH=arm CROSS_COMPILE=${CC} am335x_evm_config
Configuring for am335x_evm - Board: am335x_evm, Options: SERIAL1,CONS_INDEX=1,NAND
  GEN include/autoconf.mk.dep
  CHK include/config/uboot.release
  UPD include/config/uboot.release
  CHK include/generated/version_autogenerated.h
  UPD include/generated/version_autogenerated.h
  CHK include/generated/timestamp_autogenerated.h
  UPD include/generated/timestamp_autogenerated.h
  HOSTCC scripts/basic/fixdep
  CC lib/asm-offsets.s
  GEN include/generated/generic-asm-offsets.h
  CC arch/arm/lib/asm-offsets.s
  GEN include/generated/asm-offsets.h
  HOSTCC tools/aisimage.o
In file included from /usr/include/image.h:22:0,
                 from tools/aisimage.c:10:
/usr/include/rgbpixel.h:61:3: error: expected specifier-qualifier-list before ‘RGBpixel’
   RGBpixel () /* : red(0), green(0), blue(0), alpha(255) {} */
In file included from tools/aisimage.c:10:0:
/usr/include/image.h:40:1: error: unknown type name ‘class’
class AF_EXPORT Image
/usr/include/image.h:41:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
tools/aisimage.c:22:1: error: unknown type name ‘table_entry_t’
static table_entry_t aisimage_cmds[] = {
tools/aisimage.c:23:2: warning: braces around scalar initializer [enabled by default]
  {CMD_DATA, "DATA", "Reg Write Data"},
tools/aisimage.c:23:2: warning: (near initialization for ‘aisimage_cmds[0]’) [enabled by default]
tools/aisimage.c:23:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:24:2: warning: braces around scalar initializer [enabled by default]
  {CMD_FILL, "FILL", "Fill range with pattern"},
tools/aisimage.c:24:2: warning: (near initialization for ‘aisimage_cmds[1]’) [enabled by default]
tools/aisimage.c:24:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:25:2: warning: braces around scalar initializer [enabled by default]
  {CMD_CRCON, "CRCON", "CRC Enable"},
tools/aisimage.c:25:2: warning: (near initialization for ‘aisimage_cmds[2]’) [enabled by default]
tools/aisimage.c:25:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:26:2: warning: braces around scalar initializer [enabled by default]
  {CMD_CRCOFF, "CRCOFF", "CRC Disable"},
tools/aisimage.c:26:2: warning: (near initialization for ‘aisimage_cmds[3]’) [enabled by default]
tools/aisimage.c:26:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:27:2: warning: braces around scalar initializer [enabled by default]
  {CMD_CRCCHECK, "CRCCHECK", "CRC Validate"},
tools/aisimage.c:27:2: warning: (near initialization for ‘aisimage_cmds[4]’) [enabled by default]
tools/aisimage.c:27:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:28:2: warning: braces around scalar initializer [enabled by default]
  {CMD_JMPCLOSE, "JMPCLOSE", "Jump & Close"},
tools/aisimage.c:28:2: warning: (near initialization for ‘aisimage_cmds[5]’) [enabled by default]
tools/aisimage.c:28:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:29:2: warning: braces around scalar initializer [enabled by default]
  {CMD_JMP, "JMP", "Jump"},
tools/aisimage.c:29:2: warning: (near initialization for ‘aisimage_cmds[6]’) [enabled by default]
tools/aisimage.c:29:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:30:2: warning: braces around scalar initializer [enabled by default]
  {CMD_SEQREAD, "SEQREAD", "Sequential read"},
tools/aisimage.c:30:2: warning: (near initialization for ‘aisimage_cmds[7]’) [enabled by default]
tools/aisimage.c:30:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:31:2: warning: braces around scalar initializer [enabled by default]
  {CMD_PLL0, "PLL0", "PLL0"},
tools/aisimage.c:31:2: warning: (near initialization for ‘aisimage_cmds[8]’) [enabled by default]
tools/aisimage.c:31:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:32:2: warning: braces around scalar initializer [enabled by default]
  {CMD_PLL1, "PLL1", "PLL1"},
tools/aisimage.c:32:2: warning: (near initialization for ‘aisimage_cmds[9]’) [enabled by default]
tools/aisimage.c:32:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:33:2: warning: braces around scalar initializer [enabled by default]
  {CMD_CLK, "CLK", "Clock configuration"},
tools/aisimage.c:33:2: warning: (near initialization for ‘aisimage_cmds[10]’) [enabled by default]
tools/aisimage.c:33:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:34:2: warning: braces around scalar initializer [enabled by default]
  {CMD_DDR2, "DDR2", "DDR2 Configuration"},
tools/aisimage.c:34:2: warning: (near initialization for ‘aisimage_cmds[11]’) [enabled by default]
tools/aisimage.c:34:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:35:2: warning: braces around scalar initializer [enabled by default]
  {CMD_EMIFA, "EMIFA", "EMIFA"},
tools/aisimage.c:35:2: warning: (near initialization for ‘aisimage_cmds[12]’) [enabled by default]
tools/aisimage.c:35:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:36:2: warning: braces around scalar initializer [enabled by default]
  {CMD_EMIFA_ASYNC, "EMIFA_ASYNC", "EMIFA Async"},
tools/aisimage.c:36:2: warning: (near initialization for ‘aisimage_cmds[13]’) [enabled by default]
tools/aisimage.c:36:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:37:2: warning: braces around scalar initializer [enabled by default]
  {CMD_PLL, "PLL", "PLL & Clock configuration"},
tools/aisimage.c:37:2: warning: (near initialization for ‘aisimage_cmds[14]’) [enabled by default]
tools/aisimage.c:37:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:38:2: warning: braces around scalar initializer [enabled by default]
  {CMD_PSC, "PSC", "PSC setup"},
tools/aisimage.c:38:2: warning: (near initialization for ‘aisimage_cmds[15]’) [enabled by default]
tools/aisimage.c:38:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:39:2: warning: braces around scalar initializer [enabled by default]
  {CMD_PINMUX, "PINMUX", "Pinmux setup"},
tools/aisimage.c:39:2: warning: (near initialization for ‘aisimage_cmds[16]’) [enabled by default]
tools/aisimage.c:39:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:40:2: warning: braces around scalar initializer [enabled by default]
  {CMD_BOOTTABLE, "BOOT_TABLE", "Boot table command"},
tools/aisimage.c:40:2: warning: (near initialization for ‘aisimage_cmds[17]’) [enabled by default]
tools/aisimage.c:40:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c:41:2: warning: braces around scalar initializer [enabled by default]
  {-1, "", ""},
tools/aisimage.c:41:2: warning: (near initialization for ‘aisimage_cmds[18]’) [enabled by default]
tools/aisimage.c:41:2: warning: excess elements in scalar initializer [enabled by default]
tools/aisimage.c: In function ‘aisimage_print_header’:
tools/aisimage.c:151:4: warning: implicit declaration of function ‘get_table_entry_name’ [-Wimplicit-function-declaration]
    get_table_entry_name(aisimage_cmds, NULL, id));
tools/aisimage.c:151:4: warning: format ‘%s’ expects argument of type ‘char *’, but argument 3 has type ‘int’ [-Wformat=]
tools/aisimage.c: In function ‘aisimage_generate’:
tools/aisimage.c:317:5: warning: implicit declaration of function ‘get_table_entry_id’ [-Wimplicit-function-declaration]
     cmd = get_table_entry_id(aisimage_cmds,
tools/aisimage.c:335:25: error: request for member ‘sname’ in something not a structure or union
       aisimage_cmds[cmd].sname);
tools/aisimage.c: In function ‘aisimage_check_image_types’:
tools/aisimage.c:366:14: error: ‘IH_TYPE_AISIMAGE’ undeclared (first use in this function)
  if (type == IH_TYPE_AISIMAGE)
tools/aisimage.c:366:14: note: each undeclared identifier is reported only once for each function it appears in
tools/aisimage.c:370:1: warning: control reaches end of non-void function [-Wreturn-type]
scripts/Makefile.host:134: recipe for target 'tools/aisimage.o' failed
make[1]: *** [tools/aisimage.o] Error 1
Makefile:1007: recipe for target 'tools' failed
make: *** [tools] Error 2
[1] 14681 exit 2 make ARCH=arm CROSS_COMPILE=${CC}
What did I wrong following the description from
http://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-ARMCrossCompiler:GCC
Thank you very much for any help!
Best regards,
mcc
It's triggering on "HOSTCC" call... so my guess would be your missing
something "build-essential" related..
Robert Nelson <robertcnelson@gmail.com> [14-10-07 19:40]:
> Hi,
> From the logs:
> total 1143756
> total 1143756
Robert Nelson
http://www.rcn-ee.com/
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Hi Robert,
Thanks for your replay.
I am using Gentoo.
Unfortunately "build-essentials" says not that much, what's inside taht
package...
Am I Lost?
Best regards,
mcc
