TI sent some U-Boot OMAP3 patches to U-Boot mailing list:
http://lists.denx.de/pipermail/u-boot/2009-January/045304.html
As mentioned there, they are for EVM, but should easily (?) be adaptable to other OMAP3 boards, too. (by copying stuff from patch 08_musb.txt in attachment to beagle config?)
I put the 8 patches mentioned in that mail into a quilt patch series (see attachment), maybe it helps you to adapt them for Beagle
Patch series is against Steve's git [1].
I got one reject [2] I fixed manually. There is no
COBJS-$(CONFIG_USB_EHCI_FSL) += usb_ehci_fsl.o
in Steve's git (which should be in sync with mainline). Maybe it comes from some U-Boot USB branch merge (?).
So patch series in attachment compiles fine with
omap3_evm_config
make
but I don't know if it works
Regards
Dirk
[1] http://www.sakoman.net/cgi-bin/gitweb.cgi?p=u-boot-omap3.git;a=shortlog;h=refs/heads/omap3-dev
[2] Reject:
-- cut --
> cat drivers/usb/Makefile.rej
*************** COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o
*** 35,40 ****
COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o
COBJS-$(CONFIG_USB_SL811HS) += sl811_usb.o
# device
ifdef CONFIG_USB_DEVICE
--- 35,41 ----
+ COBJS-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o
# device
-- cut --
u-boot-omap3-musb.tar.bz2 (12.5 KB)
