Linux kernels >= 2.6.36 are using ttyOn instead ttySn for the
serials on OMAPs.Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Ack.
Ack.
Hello Alexander,
Hello Alexander,
Linux kernels>= 2.6.36 are using ttyOn instead ttySn for the
serials on OMAPs.
can you please do this for all omap3 boards?
Or we have in the end 10 patches for the same problem.
Sorry, no. I don't know which boards are using which kernel versions and there are many boards around with and SDK which are using older kernels. I think the time of the change should be decided by every board-maintainer.
Alexander
Le 02/03/2011 12:00, Alexander Holler a �crit :
Hello Alexander,
serials on OMAPs.....
Or we have in the end 10 patches for the same problem.Sorry, no. I don't know which boards are using which kernel versions and
I think the time of the change should be decided by every board-maintainer.Regards,
Alexander
Apart from Thomas' question, there seems to be no Nak for this patch -- I've taken the liberty to Cc: the board maintainer just in case -- so we might as well apply it.
Wolfgang, which tree is this patch supposed to go through? Mine because the board is ARM? yours because it is a board, not arch, patch? Or whichever?
If mine is ok then I'll apply it to next as in any cas it is not a bugfix.
Amicalement,
Cc:ing Dirk as the omap3_beagle maintainer, and Wolfgang for advice.
might as well apply it.Wolfgang, which tree is this patch supposed to go through? Mine because
whichever?
Oh, sorry, haven't seen that Dirk is the maintainer, I've only added the TI-maintainer to cc, which might be wrong.
Alexander Holler
Dear Albert ARIBAUD,
serials on OMAPs.Signed-off-by: Alexander Holler<holler@ahsoftware.de>
Ack.
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
