While preparing OMAP3 U-Boot v1 patches for upstream submission using Steve's git [1] we found that currently we use CodeSourcery toolchain and -march=armv7a configuration.
As this is incompatible to upstream configuration, discussion at U-Boot list
showed that we have to change this to use standard toolchain and more common -march option.
As example, looking at ARM11 configuration for OMAP2 in cpu/arm1136/config.mk there is a comment
# Make ARMv5 to allow more compilers to work, even though its v6.
PLATFORM_CPPFLAGS += -march=armv5
I propose to go the same way for OMAP3, too. If somebody later wants something else, he can overwrite CROSS_COMPILE at command line.
Trying to compile recent OMAP3 U-Boot git with my arm-linux-gcc and march=armv4 configuration (didn't try armv5) yet, I get
- a lot of warnings "warning: target CPU does not support interworking"
- start.S compilation in our patch fails:
start.S: Assembler messages:
start.S:466: Error: selected processor does not support `isb'
start.S:475: Error: selected processor does not support `clz r5,r4'
start.S:500: Error: selected processor does not support `isb'
try -march=armv4t, I'm not aware of any omaps using something older
than arm920t cores.
Any proposals how to change this? (Patch??)
clz (count leading zeroes) is part of the armv5te instruction set, so
try -march=armv5te.
