U-boot
I would like to inform all that the advice given by Goldie Lin DID
WORK!
I removed my current version of CodeSourcery and installed the ARM
EABI 2010.09 version along with v2010.09 version of Das U-Boot.
I issued these commands
make CROSS_COMPILE=arm-none-linux-gnueabi- mrproper
make CROSS_COMPILE=arm-none-linux-gnueabi- omap3_beagle_config
The I copied the u-boot.bin file to a SD card formatted FAT16 along
with a copy of MLO from the Angstrom card I got along with my BB xm. I
put the SD card in the BB Xm and it worked.
Now its on to making my own version of MLO which I understand is x-
loader renamed to MLO.
Thanks Goldie!
David
Did you compile v2010.09 of Das U-Boot?
I has similar issue with CodeSourcery ARM EABI 2010.09
Please try to use previous one (2010q1) to re-compile it.
I've also built this version of u-boot with Crosstool-NG 1.8.2 w/ARM
EABI and it boots a C4 board just fine.
I put the SD card in the BB Xm and it worked.
I'm wondering if there is a way to verify that all components are
properly initialized. I'm specifically interested in DSS2 (more
specifically, S-Video) support in the kernel and was expecting u-boot to
do some initialization. But unlike the old u-boot (in the validation
image) the current u-boot does not show the color bars on S-Video. And
I have yet to find a kernel that finds any displays at boot time. So
I'm not sure if the problem is u-boot initialization or kernel
configuration.
One thing I'm concerned with is that the validation image u-boot and
kernel work with DSS1 and DSS2 is the new implementation. So I'd rather
get the latter working if possible, just to stay up with current work.
I believe that's correct though in my case I haven't found a reason to
update this since it does exactly what I need it to do: initiliaze mmc
and read u-boot from the SD card.
2010/11/28 Dave Wiebe <dwiebe.dwiebe@gmail.com>
WORK!
Congratulations!
CROSS_COMPILE prefix of ARM EABI should be “arm-none-eabi-”,
not “arm-none-linux-gnueabi-” for ARM GNU/Linux EABI.
Or maybe just a typo, okay.
