Hi all,
I have been having an issue where when heavily using a serial UART at high speed I would get a lot of overrun errors on the port and eventually the BBB would hang/appear to power off. It was very strange, we couldn’t get kernel debugging at all, it did appear that is had powered down.
This morning I was making some changes to a device tree (attached) and managed to fix the problem, by disabling the wkup_m3 the problem appears to have disappeared.
Usually it would happen after around 2-3 hours and so far have uptime of 12+ hours on 2 test units I have on the bench so it is looking good.
Now…why is this the case. UART 2 is the one heavily used and the baud rate is 3Mbps and we are pretty much saturating the link at times.
What exactly does the wkup_m3 do?
Is it safe to keep it disabled? (Older device trees didn’t seem to use it)
Where would this fault lie, hardware or software and who should I report it to?
I’ve been pulling my hair out for a week and thankfully appear to have a solution!!!
Happy Thanksgiving all.
Lee
testOverlay.dts (1.36 KB)
