Thanks for your valuable suggestions.
For the recovery UART I follow the instructions:
http://elinux.org/BeagleBoardRecovery#UART_recovery
I could successfully run the "pserial" and "ukermit" commands. Please
see the below outputs.
root@vector-laptop:/usr/local/src/serial_boot/omap-u-boot-utils# ./
pserial -p /dev/ttyUSB0 -f x-load.bin
Waiting For Device ASIC ID: Press Ctrl+C to stop
ASIC ID Detected: OMAP 3430 with ROM Version 0x0757
Sending 2ndFile:
Downloading file: 100.000% completed (12432/12432 bytes)
File download completed.
ukermit -p /dev/ttyUSB0 -f u-boot.bin
Downloading file: 100.000% completed (213664/213664 bytes)
File Download completed.
After these commands it displays shell command prompt instead of the
below message as mention in the link http://elinux.org/BeagleBoardRecovery#UART_recovery
## Start Addr = 0x80008000
Starting OS Bootloader from UART ...
U-Boot 2009.03-rc2-00013-gefb4734 (C3A4r 18 2009 - 10:55:33)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #047a00030000000004013f780601000c
I didn't get the above message (u-boot command prompt). What might be
the problem?
Could you please suggest me. I am stuck up here..........
Thanks&Regards,
Kishore Kumar Boddu
