UARTS in kernel 4.4: no /dev/ttO* ?
Working in kernel 4.4.16-bone-rt-r11 and am not seeing the corresponding entries in /dev/ for the enabled UARTS.
My custom DTS (BB-APA-01) enables a number of UARTS but I am not seeing the corresponding /dev/ttyO2, ttyO4, ttyO5, etc.
Tried also loading the BB-UART2-00A0.dtbo from /lib/firmare/ as you can see below when I cat slots.
root:~# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-APA-01
5: P-O-L- 1 Override Board Name,00A0,Override Manuf,BB-ADC
6: P-O-L- 2 Override Board Name,00A0,Override Manuf,BB-UART2
root:~# ls /dev/tty*
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyACM0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyS0
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58 /dev/ttyS1
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59 /dev/ttyS2
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6 /dev/ttyS3
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60 /dev/ttyS4
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61 /dev/ttyS5
What am I missing here? When a UART is loaded into slots should it then be labeld ttyOX in /dev just as in 3.18?
/dev/ttyS?
Mike
Don’t think the ttyS’s are it. I know for sure in 3.18 you use the /ttyO2 or whatever number uart you enable.
Can anyone confirm that in 4.4 the UARTS show as /ttyS* ?
Going to check my .dts.
william@beaglebone:~$ dmesg |grep tty
[ 0.000000] Kernel command line: console=tty0 console=ttyO0,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait ip v6.disable=1
[ 0.002187] console [tty0] enabled
[ 0.002223] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 1.998154] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 2.884801] console [ttyS0] enabled
william@beaglebone:~$ clear
william@beaglebone:~$ ls /sys/devices/
armv7_cortex_a8 breakpoint platform soc0 software system tracepoint virtual
william@beaglebone:~$ ls /sys/devices/platform/
alarmtimer cpufreq-dt leds omap-pcm-audio pm33xx.0 power serial8250 ti-cpufreq.0
bone_capemgr fixedregulator@0 ocp opp_table0 pmu reg-dummy soc uevent
william@beaglebone:~$ cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
william@beaglebone:~$ ls /lib/firmware/ |grep UART
BB-UART1-00A0.dtbo
BB-UART2-00A0.dtbo
BB-UART2-RTSCTS-00A0.dtbo
BB-UART3-00A0.dtbo
BB-UART4-00A0.dtbo
BB-UART4-RS485-00A0.dtbo
BB-UART5-00A0.dtbo
william@beaglebone:~$ sudo sh -c"echo ‘BB-UART2’ > /sys/devices/platform/bone_capemgr/slots"
[sudo] password for william:
sh: 0: Illegal option -h
william@beaglebone:~$ sudo sh -c “echo ‘BB-UART2’ > /sys/devices/platform/bone_capemgr/slots”
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-UART2
[778201.669492] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 198, base_baud = 3000000) is a 8250
william@beaglebone:~$ ls /sys/devices/platform/ocp/
40300000.ocmcram 48030000.spi 48060000.mmc 48310000.rng 53500000.aes
40302000.ocmcram_nocache 48038000.mcasp 480c8000.mailbox 49000000.edma 56000000.sgx
44e07000.gpio 4803c000.mcasp 480ca000.spinlock 49800000.tptc driver_override
44e09000.serial 48042000.timer 4819c000.i2c 49900000.tptc modalias
44e0b000.i2c 48044000.timer 481a0000.spi 49a00000.tptc ocp:l4_wkup@44c00000
44e35000.wdt 48046000.timer 481ac000.gpio 4a100000.ethernet of_node
44e3e000.rtc 48048000.timer 481ae000.gpio 4a300000.pruss power
47400000.usb 4804a000.timer 481d8000.mmc 4c000000.emif subsystem
48024000.serial 4804c000.gpio 48200000.interrupt-controller 53100000.sham uevent
william@beaglebone:~$ ls /sys/devices/platform/ocp/48024000.serial
driver driver_override modalias of_node power subsystem tty uevent
william@beaglebone:~$ ls /sys/devices/platform/ocp/48024000.serial/tty
ttyS2
william@beaglebone:~$ apt-cache search setserial
setserial - controls configuration of serial ports
william@beaglebone:~$ sudo apt-get install setserial
The following NEW packages will be installed:
setserial
0 upgraded, 1 newly installed, 0 to remove and 13 not upgraded.
Need to get 49.9 kB of archives.
After this operation, 139 kB of additional disk space will be used.
william@beaglebone:~$ setserial -g /dev/ttyS[0-5]
/dev/ttyS0, UART: 8250, Port: 0x0000, IRQ: 158
/dev/ttyS1, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS2, UART: 8250, Port: 0x0000, IRQ: 198
/dev/ttyS3, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS4, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS5, UART: unknown, Port: 0x0000, IRQ: 0
http://bfy.tw/7Hr5
Anyhow, consider this horse beaten to death.
ttyO* is for the omap driver. If i’m not wrong the kernel 4.4 use the driver 8250.
You can switch back to the omap driver i’ the config of the kernel.
Thanks for the info guys.
Why is it that ttyS* are all listed when no BB-UART has been loaded into slots?
Work flow before was straight forward:
  • Load a .dtbo
  • Corresponding /ttyO* loaded.
Now I am unsure. When the BBB boots it shows all the /dev/ttyS*
Do I still have to load the corresponding .dtbo’s?
Do I have to run the command
to bring up UARTS after every boot?
