I am using ttyO0 as a serial console for another linux machine. When the BBB boots, it sends out messages out ttyO0 which is connected to another machines console. Since a getty is running and the messages get echo’d back, uboot reacts to those messages which stops the boot process…
So the bottom line is this:
How do I get uboot to NOT send out boot messages to ttyO0?
Here is a sample of the messages sent to ttyO0
U-Boot 2013.10-00016-g6adb529 (Feb 06 2014 - 14:54:24)^M
^M
I2C: ready^M
DRAM: 512 MiB^M
WARNING: Caches not enabled^M
NAND: 0 MiB^M
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1^M
*** Warning - readenv() failed, using default environment^M
^M
Net: not set. Validating first E-fuse MAC^M
cpsw, usb_ether^M
Hit any key to stop autoboot: 1 ^H^H^H 0 ^M
gpio: pin 53 (gpio 53) value is 1^M
Card did not respond to voltage select!^M
