Hello all,
I have upgraded to lucid and some problems with rootstock appeared.
Rootstock couldn't finish successfully.
First issue: Rootstock's error message "792: Bad substitution"
Second one: Rootstock's error message "segmentation fault"
After some googling, I ended up with the following work-arounds:
Edit /usr/bin/rootstock file:
1) first line, change "#!/bin/sh" to "#!/bin/bash"
2) function setup_kernel_image(), line 381 for me, change
"KERNEL_IMG_REL=${KERNEL_IMG_REL/_*_armel.deb}" to "KERNEL_IMG_REL=$
{KERNEL_IMG_REL%%_*}"
Hope it will be useful and time-saving for those who struggle with the
same problem.
Cheers
Meereck
Hmm, doesnt seem to be solved.
Perhaps, too many seed packages cause a problem.
The following fails:
#!/bin/sh
sudo rootstock --fqdn BeagleBoard --login ubuntu --password lucid --
imagesize 2G --dist lucid \
--serial ttyS2 --seed mc,minicom,openssh-
server,apache2,php5,libapache2-mod-php5,wget,linux-firmware,wireless-
tools,usbutils,build-essential,xfce4,gdm,xubuntu-gdm-theme,xubuntu-
artwork \
--script fixup.sh --components "main universe multiverse" \
--kernel-image http://rcn-ee.net/deb/lucid/v2.6.33.4-l3/linux-image-2.6.33.4-l3_1.0lucid_armel.deb
ends up with:
Setting up build-essential (11.4build1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for initramfs-tools ...
Processing triggers for python-support ...
/usr/bin/rootstock: line 282: 32083 Segmentation fault qemu-
system-arm $QEMUOPTS -append "${APPEND}" > $QEMUFIFO 2>&1
I: Virtual Machine done
I: Creating tarball from rootfs
I: Mounting temporary Image
I: ARM rootfs created as /home/meereck/BeagleBoard/UbuntuLucid/armel-
rootfs-201005282218.tgz
I: Extracting vmlinuz from *.deb
cp: cannot stat `/tmp/tmp.wGlYBYizCA/tmpmount/boot/initrd.img-*': No
such file or directory
Has anyone experienced similar behaviour?
Yeap, both are known bugs... the bashism fix has been submitted,
upstream (ubuntu) just hasn't released rootstock with the fix it yet..
https://bugs.launchpad.net/project-rootstock/+bug/575854
the other bug can be fixed by dropping 'xfce4 and gdm' from your seed..
https://bugs.launchpad.net/ubuntu/+source/qemu-kvm/+bug/532733
will it work similarly if I install xfce4 and gdm packages after the
board is running?
Regards
Meereck
Yeap, that'll work just fine...
Regards
Still not working:
#!/bin/sh
tools,usbutils,build-essential \
--swapsize 256 --script fixup.sh --components "main universe
multiverse" \
yields:
/usr/bin/rootstock: line 282: 16627 Segmentation fault qemu-
rootfs-201005311235.tgz
cp: cannot stat `/tmp/tmp.pFO8QWTIYD/tmpmount/boot/initrd.img-*': No
It might be related to this bug: https://bugs.launchpad.net/project-rootstock/+bug/585810
However, if I run it without "--swapsize 256", it hangs.
I have no other clues what to do:(
regards M.
Still not working:
#!/bin/sh
multiverse" \
yields:
Yeap it is. Two nasty bugs in rootstock...
Remove some more 'seed' values and install later.. apache, build-essential
