Pantelis / Robert
Here is a fix for musb (attached), causing some devices not to enumerate at all.
Tested with a wifi usb device.
regards
Pantelis / Robert
regards
Just for me to to understand: With the comment I would expect for
500mA a value of 250 which fits in 8bits. Is the comment wrong or is
there something else going wrong?
Andreas
Interesting find..
In most cases with musb:
u8 power;
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/musb/omap2430.c#n62
For the Bone's hardware glue, it's wrapped to 32bit here:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/musb/musb_dsps.c#n569
Pantelis / Robert
Tested with a wifi usb device.regards
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.Just for me to to understand: With the comment I would expect for
As pointed by Robert [1]
Device tree blob provides a value of 500mAmp via :
+&usb_otg_hs {
+ interface_type = <1>;
+ power = <500>; <--------------- 500mAmp
+ status = "okay";
Its the sw that does the divide by 2 to get value of 250.
Problem happens when you try to read DT and truncate the 500 decimal
to 244 decimal here [1]
regards
[1] musb_dsps.c « musb « usb « drivers - kernel/git/torvalds/linux.git - Linux kernel source tree
Some more oddness:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/devicetree/bindings/usb/omap-usb.txt#n19
According to the binding doc's it's actually suppost to be the value *2.
So we should be using 250 to get 500mA..
While editing a patch i noticed:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/am33xx.dtsi#n338
So yeah, these should be 250, so it's just hacking off the top bits
and using the lower 8 bits..
Robert
This is the place where the power value from DT gets multiplied by two:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/musb/musb_core.c#n1992
So what is wrong on your Ubuntu 3.8 kernel is this patch:
patches/usb/0009-MUSB-Hack-around-to-make-host-port-to-work.patch
diff --git a/arch/arm/boot/dts/am335x-bone-common.dtsi
b/arch/arm/boot/dts/am335x-bone-common.dtsi
index 23a8b01..bf34fc1 100644
--- a/arch/arm/boot/dts/am335x-bone-common.dtsi
+++ b/arch/arm/boot/dts/am335x-bone-common.dtsi
@@ -373,3 +373,9 @@
&aes {
status = "okay";
So in other words, the fix is still valid, since 1000mAmp is a valid
use case for host to supply that much current.
So DT can provide <500> as a valid value and SW should not make that
into 244 !!!
