Ubuntu 9.04 on DevKit8000
Hi all,
this is my first post then....hello all.
Yesterday i've buy a devkit8000 board with 7' touch screen. I've read
all manuals on CD and i've tried to boot the board with Android
successfully.
I don't know Android system and it does not appeal to a lot to me,
then i want try to boot Ubuntu 9.04 (for BeagleBoard) into my
devkit8000 and see gnome on LCD attached (I hope).
I've read a lot of posts about difference between beagleBoard and
DevKit8000, but all about Android.
I have understood that the kernel 2.6.29 is ok for devkit8000. Is it
right?
I can follow the steps at this point http://elinux.org/BeagleBoardUbuntu#Build_Image
I want update the u-boot using this step http://elinux.org/BeagleBoardUbuntu#Upgrade_U-Boot
....I mistake?
I must recompile the kernel with other features?
Thank a lot and Best Regards.
Be very careful, that wiki is beagleboard 'only' at this point. If
you'd like to add devkit8000 options be my guest..
Hi all,
successfully.
right?
I can follow the steps at this point BeagleBoardUbuntu - eLinux.org
You can follow those steps, but that *.deb file listed will not run on
the devkit8000 (the rootfilesystem will be completely fine..) , so
ignore the '--kernel-image' option for the moment and supply your
'own' uImage and modules...
I do not have a devkit8000, but if you'd like to add kernel (*deb)
support, here's my current build script:
https://code.launchpad.net/~beagleboard-kernel/+junk/2.6-dev
If all it requires is a defconfig tweak in the OMAP Board type section:
thats a gud initative…
ubuntu 9.04 on devkit8000.
Hi mitsus,
did you have any success ??
I'm also very interrested in bringing Ubuntu to DevKit8000.
mitsus schrieb:
Hi Jochen,
yesterday i've successfully run debian lenny with full xorg server on
DevKit8000. It work great with my LCD 7''...but i've a prblems with
touch screen. In this afternoon i post my Xorg logs.
The second step is run ubuntu filesystem, but i think that debian
lenny is the best for this board.
I am working on USB 3G module and testing on beagle board. In Angstorm WVDIAL is not there.
How to test this USB 3g module in beagle board
–Sanjeev
There is a wvdial recipe in OE, but I was not able to get it work. Some online comments I got is that some APIs used by wvidal are not implemented in ARM platform, and therefore will not work in beagleboard.
At the end, I choose to use pppd and it works.
  • Thomas
Thanks Thomas,
could you send me how to use pppd to make 3g work?
Sanjeev
Sanjeev,
you don’t actually need a wvdial program. Read here and change ttyUSB0 with your serial port name:
http://groups.google.com/group/beagleboard/msg/5314603061535756?pli=1
You may also look at this thread:
http://mail.google.com/mail/#label/beagleboard/125205ff2943ee5b
  • Thomas
use this instead:
http://groups.google.com/group/beagleboard/browse_thread/thread/7f119201fb4fe376/4082153335f49557?lnk=gst&q=pppd#4082153335f49557
  • Thomas
Hi Thomas,
How to add usb_modswitch for beagle board (Angstrom)?
–Sanjeev
After inserting e156 3g module i am getting these messages.
root@beagleboard:~# usb 2-1: new high speed USB device using musb_hdrc and address 2
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
usb 2-1.4: new high speed USB device using musb_hdrc and address 3
usb 2-1.4: device v12d1 p1003 is not supported
usb 2-1.4: configuration #1 chosen from 1 choice
usb-storage: probe of 2-1.4:1.0 failed with error -1
usb 2-1.4: USB disconnect, address 3
usb 2-1: reset high speed USB device using musb_hdrc and address 2
usb 2-1.4: new high speed USB device using musb_hdrc and address 4
usb-storage: probe of 2-1.4:1.0 failed with error -5
usb-storage: probe of 2-1.4:1.1 failed with error -5
usb-storage: probe of 2-1.4:1.2 failed with error -1
usb-storage: probe of 2-1.4:1.3 failed with error -1
usbserial: disagrees about version of symbol struct_module
option: disagrees about version of symbol struct_module
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 004: ID 12d1:1003 Huawei Technologies Co., Ltd. E220 HSDPA Modem
How to add device with v12d1 p1003 ID? what are these errors
–Sanjeev
After running .sh file, here is the result
root@beagleboard:/# sh internet-start.sh
/usr/sbin/pppd: unrecognized option ‘/dev/ttyUSB0’
pppd version 2.4.3
Usage: /usr/sbin/pppd [ options ], where options are:
Communicate over the named device
Set the baud rate to
: Set the local and/or remote interface IP
addresses. Either one may be omitted.
asyncmap Set the desired async map to hex
auth Require authentication from peer
connect
Invoke shell command
to set up the serial line
crtscts Use hardware RTS/CTS flow control
defaultroute Add default route through interface
file Take options from file
modem Use modem control lines
mru Set MRU value to for negotiation
See pppd(8) for more options.
root@beagleboard:/#
Please help me to solve this…
Sanjeev
3G module is stoping after connecting, here is the log for more info.
root@beagleboard:/# sh internal.sh
send (ATZ^M)
expect (OK)
^M
^RSSI:21^M
TZ^M^M
OK
– got it
send (AT+CGDCONT=1,“IP”,“gprssouth.cellone.in”,"",0,0^M)
expect (OK)
^M
AT+CGDCONT=1,“IP”,“gprssouth.cellone.in”,"",0,0^M^M
OK
– got it
send (ATDT99#^M)
expect (CONNECT)
^M
ATDT
99#^M^M
CONNECT
– got it
send (dc^M)
Serial connection established.
Using interface ppp0
Connect: ppp0 <–> /dev/ttyUSB1
LCP: timeout sending Config-Requests
Connection terminated.
Receive serial link is not 8-bit clean:
Problem: all had bit 7 set to 0
send (ATZ^M)
expect (OK)
ATZ^M^M
OK
– got it
expect (OK)
^M
OK
– got it
send (ATDT99#^M)
expect (CONNECT)
^M
ATDT
99#^M^M
NO CARRIER^M
^M
^BOOT:24415102,0,0,0,85^M
alarm
Failed
Connect script failed
Modem hangup
root@beagleboard:/
Is there anything i missed to connect the modem?
Sanjeev
