Ubuntu does not boot
I have a funny problem with Ubuntu on my BBB (which worked before on this hardware). Boot process stops with a message
[ 2.753228] Freeing init memory: 288K
[ 3.804981] init: ureadahead main process (85) terminated with status 5
[ 9.098069] libphy: PHY 4a101000.mdio:01 not found
[ 9.103184] net eth0: phy 4a101000.mdio:01 not found on slave 1
Ethernet is not plugged and does not need to be configured - so it would be OK for me when booting continues alsow without PHY/Ethernet initialisation.
Any ideas what I can do to let Ubuntu boot fully - also without Ethernet?
Thanks!
mdio:01 is the un-connected "2nd" phy...
What's on the hdmi display? Did you recently upgrade to v3.14.x-ti or
something?
There is no display connected , I operate it only via serial console at the moment. In /boot kernel 3.8.13-bone20 can be found, AFAIR it is still an Ubuntu 12.04.
Okay... So what did you do to it?
It wouldn't just stop booting, unless you changed something/yanked
power one too many times/etc...
OK, it seems SD-card is dying…unfortunately I can’t find the Ubuntu 12.02 image any more - where can I download it?
