Ubuntu oneiric rcn-ee.net r3 with gst-dsp and dsp-bridge error
I've installed Ubuntu oneiric in my beagleboard using the steps in
http://elinux.org/BeagleBoardUbuntu, using
http://rcn-ee.net/deb/rootfs/oneiric/ubuntu-11.10-r3-minimal-armel.tar.xz
image, and installed gst-dsp with the steps described in the same wiki.
When I execute I get the following errors in dmesg:
[ 2080.014068] procwrap_detach: deprecated dspbridge ioctl
and from gstreamer:
0:00:01.488189698 5391 0xdb8580 ERROR dsp
gstdspvdec.c:180:create_node:<dspvdec0> dsp node create failed
I'm using the following command:
gst-launch filesrc location=videos/bourne.mp4 ! qtdemux ! dspvdec ! omapfbsink
I'm also attaching a GST_DEBUG=5 log output and my complete dmesg.
It seems I'm using a old dspbridge? If so, where can I find a newer one?
Any help would be appreciated,
dmesg (20 KB)
output.err (1.02 MB)
output (108 Bytes)
Please, upgrade to v3.2.1-x3..
wget http://rcn-ee.net/deb/oneiric-armel/v3.2.1-x3/install-me.sh
/bin/bash install-me.sh
in v3.2.x, dspbridge works better then in v3.1.x, with my kernel
images on the xM..
Although, for some reason it seems to lag at certain points while
playing video back..
BeagleBoardUbuntu - eLinux.org, using
and from gstreamer:
images on the xM..
Thanks! Will do! Didn't expect an answer so quick!
Robert Nelson
http://www.rcn-ee.com/
Unfortunately I get the exact same error as before.
Yeah, actually ran into the same problem last week, that kernel build
had my fixes to get things working again. :slight_smile:
[snip]
I'm seeing this from dmesg.
[ 20.422668] bridgedriver: module is from the staging directory, the
quality is unknown, you have been warned.
This is expected?
Robert Nelson
Yeap, any kernel driver under /drivers/staging/ gets that warning when loaded..
