ubuntu + sshd doens't load on startup
Dear all. My fresh ubuntu console installation doens't starts ssh
daemon when it boots.
Don't know why? I've checked /var/log/auth.log, kern.log, messages,
dmesg... There is no error.
When I run "/etc/init.d/ssh start" it runs fine.
Some help?
Thank you,
Sergio.
Hi Sergio,
What 'package' did you install thru apt and friends?
If you didn't use "openssh-server" try that first...
Otherwise is their any clues in your networking logs at startup?
I can confirm that openssh-server package works well on BeagleBoard,
and that it starts automatically after boot.
Regards
Thanks! The openssh version is 1:5.1p1-6ubuntu2, and I can start it
manually without problems (running "/etc/init.d/ssh start" command).
I think that problem is with network interface (D-link DUB-E100). In
example I've configure fstab to automount samba shares on startup and
doesn't works, but I can mount without problem manually after boot
(ie: command "mount /mnt/mysamba"). Same for ssh daemon.
Meereck are you using Ubuntu karmic also? Or are you using Amgstrom?
Sergio.
Hi all,
I have upgrade upstart from 0.6.3-10 to 0.6.3-11. Now sshd runs
automatically at startup but samba doesn't automount on boot.
Sergio,
I'm having very similar problems. Ubuntu/Karmic. Sshd will not start on boot. And, a Windows share won't mount on boot.
I can easily start sshd and mount the share once up and running.
When you say you upgraded upstart, where did you get this upgrade?
-jeff
I am using Karmic with kernel v2.6.32.10-x11.
The "openssh-server" package was installed after the system was
running - e.g. not during rootstock "-seed" process.
