I successfully ran Angstrom after building ti-x11-demo-image, however the kernel threw this error while booting and I thought maybe it would better to report it:
[ 46.196075] NET: Registered protocol family 17
[ 46.200592] NET: Registered protocol family 15
[ 46.205230] lib80211: common routines for IEEE802.11 drivers
[ 46.210968] ThumbEE CPU extension supported.
[ 46.215270] Power Management for TI OMAP3.
[ 46.220733] Division by zero in kernel.
[ 46.224639] [] (unwind_backtrace+0x0/0xdc) from [] (Ldiv0+0x8/0x10)
[ 46.232757] [] (Ldiv0+0x8/0x10) from [] (0xcf81ff88)
[ 46.239562] Division by zero in kernel.
[ 46.243469] [] (unwind_backtrace+0x0/0xdc) from [] (Ldiv0+0x8/0x10)
[ 46.251586] [] (Ldiv0+0x8/0x10) from [] (0xcf81ff88)
[ 46.258422] SmartReflex driver initialized
[ 46.273406] ------------[ cut here ]------------
[ 46.278106] WARNING: at arch/arm/mach-omap2/dpll.c:439 omap3_noncore_dpll_set_rate+0x228/0x26c()
[ 46.286926] Modules linked in:
[ 46.290039] [] (unwind_backtrace+0x0/0xdc) from [] (warn_slowpath_common+0x4c/0x80)
[ 46.299468] [] (warn_slowpath_common+0x4c/0x80) from [] (omap3_noncore_dpll_set_rate+0x228/0x26c)
[ 46.310150] [] (omap3_noncore_dpll_set_rate+0x228/0x26c) from [] (omap2_clk_set_rate+0x24/0x34)
[ 46.320648] [] (omap2_clk_set_rate+0x24/0x34) from [] (clk_set_rate+0x4c/0xac)
[ 46.329681] [] (clk_set_rate+0x4c/0xac) from [] (program_opp+0xe0/0x180)
[ 46.338165] [] (program_opp+0xe0/0x180) from [] (resource_set_opp_level+0xf0/0x16c)
[ 46.347625] [] (resource_set_opp_level+0xf0/0x16c) from [] (set_opp+0x3c/0x100)
[ 46.356719] [] (set_opp+0x3c/0x100) from [] (update_resource_level+0xa8/0xcc)
[ 46.365661] [] (update_resource_level+0xa8/0xcc) from [] (set_freq+0x110/0x138)
[ 46.374755] [] (set_freq+0x110/0x138) from [] (update_resource_level+0xa8/0xcc)
[ 46.383850] [] (update_resource_level+0xa8/0xcc) from [] (omap_target+0x5c/0x78)
[ 46.393035] [] (omap_target+0x5c/0x78) from [] (__cpufreq_driver_target+0x5c/0x78)
[ 46.402404] [] (__cpufreq_driver_target+0x5c/0x78) from [] (cpufreq_governor_performance+0x48/0x5c)
[ 46.413269] [] (cpufreq_governor_performance+0x48/0x5c) from [] (__cpufreq_governor+0x160/0x1bc)
[ 46.423828] [] (__cpufreq_governor+0x160/0x1bc) from [] (__cpufreq_set_policy+0x190/0x220)
[ 46.433898] [] (__cpufreq_set_policy+0x190/0x220) from [] (cpufreq_add_dev+0x3dc/0x564)
[ 46.443695] [] (cpufreq_add_dev+0x3dc/0x564) from [] (sysdev_driver_register+0xb0/0x120)
[ 46.453613] [] (sysdev_driver_register+0xb0/0x120) from [] (cpufreq_register_driver+0xec/0x1cc)
[ 46.464111] [] (cpufreq_register_driver+0xec/0x1cc) from [] (do_one_initcall+0x5c/0x1bc)
[ 46.473999] [] (do_one_initcall+0x5c/0x1bc) from [] (kernel_init+0xa4/0x128)
[ 46.482849] [] (kernel_init+0xa4/0x128) from [] (kernel_thread_exit+0x0/0x8)
[ 46.491699] —[ end trace 4f70a4c9d32c5d87 ]—
[ 46.496582] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 46.504974] registered taskstats version 1
[ 46.524841] Console: switching to colour frame buffer device 80x30
[ 46.546264] regulator_init_complete: incomplete constraints, leaving VAUX3 on
The kernel’s full name as built by OE is: uImage-2.6.32-r88+gitra6bad4464f985fdd3bed72e1b82dcbfc004d7869-beagleboard.
-Ilyes Gouta
