uImage with fix for alsa crash
The angstrom uImage[1] has been update to fix the alsa crash.
regards,
Koen
[1] http://www.angstrom-distribution.org/demo/beagleboard/uImage
for some reason that uImage didn't work with my USB network device
when I went to scp over a sound file for testing. When I copied the
older uImage and rebooted, the USB networking was there again.
Will copy over a file now, try the ALSA-fix one and try to play the
file and post back.
I still get the crash and I tried:
mplayer -ao oss -nosound palinLordMakeAWay.wav
mplayer palinLordMakeAWay.wav
cat palinLordMakeAWay.wav > /dev/dsp
tried changing the system sound settings and clicking the "Test"
button
they all ended with a locked up system.
I have also downloaded and tried the 'fixed' uImage and have had the
same results.
it crashes unless -nosound is used :o(
Paul
same results.
Could you try
http://ewi546.ewi.utwente.nl/~koen/uImage-2.6.26+2.6.27-rc7+r9+gite1c49d7d22af768188e2a54c167ed79919361e55-r9-beagleboard.bin
That seems to fix the issue for more people than the .26 kernel. It's
still a band-aid, since the root cause hasn't been found or fixed yet.
Matching modules-<version>.tgz is in the same dir.
regards,
Koen
The .27 kernel does fix my problem and i can finally hear sound!
band-aid or not - it works so i'm happy.
Paul
I tried this 27 kernel together with the 20080920 rootfs. And the
sound works fine. But my DVI-D output no longer works -- i.e. my
monitor complains about the signal being out of range and shuts
off. :slight_smile:
So to summarize my findings:
  - The 2008-09-25 uImage works well with the 2008-09-20 rootfs -- but
any Alsa output causes a kernel panic crash.
  - The 26-27 - r9 uImage has sound, but doesn't run the monitor / X
etc.
Now if we could combine the best characteristics of each uImage, we'd
be home.
Best regards,
Geof
