I am unable to access/talk to my Beaglebone Black after doing a fresh netinstall with the following command:
sudo ./mk_mmc.sh --mmc /dev/mmcblk0 --firmware --serial-mode --dtb am335x-boneblack --distro trusty
It neither shows up connected with ethernet on my network nor does the serial console connectivity display anything. And I had tried this precise method earlier and both ways to access the device were working just fine.
Please find a screenshot of the files on the programmed microSD card attached. Any help to resolve will be much appreciated!
Maybe you aught to buy a serial debug cable, and see why it doesn’t work. There are probably 100’s of reason why this could have failed, for which a single person could probably make a different guess a day, for the next 6 months, and still guess wrong.
Passed that, only one person on this group could really start guessing, as he wrote that script, and knows how it works.
"--serial-mode" implies connecting a physical serial port to the debug
header on the black.
I did have a serial debug cable connected :). Turned out the right angle serial connector between the cable and the J1 went bad.
But the BBB seems to be booting into the default debian in the eMMC rather than the Ubuntu programmed into the microSD card using netinstall.
Here’s the output:
U-Boot 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06), Build: jenkins-github_B5
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
cpsw
Is the SD card being recognized correctly by uboot?
boot into the eMMC and:
sudo dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=10
u-boot gone from the eMMC
Here's the output:
jenkins-github_B5
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
I could do that but if it truly isn't recognizing the microSD, wouldn't
formatting eMMC render it non-usable? I'm not that familiar with BBB, have
not played around with U-boot off late nor have JTAG etc , so would rather
not take a chance. Did the output indicate that the microSD is NOT being
recognized? Thanks!
Nope, you cut it off too early..
Here’s more output. Thanks!
U-Boot SPL 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
cpsw
Card did not respond to voltage select!
switch to partitions #0, OK
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
818 bytes read in 28 ms (28.3 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-3.8.13-bone70 …
5617184 bytes read in 344 ms (15.6 MiB/s)
loading /boot/dtbs/3.8.13-bone70/am335x-boneblack.dtb …
26098 bytes read in 38 ms (669.9 KiB/s)
loading /boot/initrd.img-3.8.13-bone70 …
2867606 bytes read in 190 ms (14.4 MiB/s)
debug: [console=ttyO0,115200n8 root=UUID=8b8367b0-c090-4d28-8d50-309dd3f2d4b1 r.
debug: [bootz 0x82000000 0x88080000:2bc196 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x55b620 ]
Loading Ramdisk to 8fd43000, end 8ffff196 … OK
Loading Device Tree to 8fd39000, end 8fd425f1 … OK
Starting kernel …
[ 0.372801] omap2_mbox_probe: platform not supported
[ 0.527720] tps65217-bl tps65217-bl: no platform data provided
[ 0.591106] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.628213] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.665321] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.702431] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.718221] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P)
[ 0.727781] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.734516] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BO)
[ 0.750892] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.814032] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested b8
[ 0.825720] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.832993] pinctrl-single 44e10800.pinmux: could not request pin 21 on devie
Loading, please wait…
systemd-fsck[207]: rootfs: clean, 84709/233856 files, 485265/933632 blocks
Debian GNU/Linux 7 beaglebone ttyO0
BeagleBoard.org Debian Image 2015-03-01
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
The IP Address for usb0 is: 192.168.7.2
beaglebone login: [ 28.197242] libphy: PHY 4a101000.mdio:01 not found
[ 28.202308] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 34.002771] libphy: PHY 4a101000.mdio:01 not found
[ 34.007883] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 34.787891] libphy: PHY 4a101000.mdio:01 not found
[ 34.792990] net eth0: phy 4a101000.mdio:01 not found on slave 1
Here you, yeah it's not reading the microSD...
try a different card..
