Hi All,
I am trying to boot the beaglebone black from sd card, but boot process stops with below error.
I have taken u-boot and rootfs from the below link
wget http://s3.armhf.com/dist/bone/bone-uboot.tar.xzuE
wget http://s3.armhf.com/dist/bone/ubuntu-trusty-14.04-rootfs-3.14.4.1-bone-armhf.com.tar.xz
I have attached the uEnv.txt file,pleas everify.
U-Boot SPL 2013.04-dirty (Jul 10 2013 - 14:02:53)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
557 bytes read in 4 ms (135.7 KiB/s)
Running uenvcmd …
syntax error
24808 bytes read in 35 ms (691.4 KiB/s)
Bad Linux ARM zImage magic!
** File not found /boot/uImage **
U-Boot#
what could be the possible mistakes for this error, please help me to resolve this issue.
Thanks and regards,
Madhu
uEnv.txt (533 Bytes)
