Unable to display GUI on to monitor display using beagleboard-xm
Hi all,
I have taken the pre-build images from TI site i.e. beagleboard-xm.tar.gz and copied on to sd card following the instruction in TI site and It could able to boot and through some messages like adb_open on to serial port but
It is not able to display any GUI graphic on to the acer monitor which i am using to display.
components I am using are:
1. Beagleboard-XM Rev B
2. DVI to HDMI cable which is given along with the beagleboard.
3. Connector between HDMI and VGA connector of the acer monitor, because pins on HDMI connector are different from VGA connector of the acer monitor which I am using.
4. acer monitor for displaying GUI from beagleboard-xm.
software components used:
beagleboard-xm.tar.gz from the site
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevKit/TI_Android_GingerBread_2_3_DevKit_1_0/index_FDS.html
Queries:
1. Will the beagleboard-xm and prebuild images support the general VGA acer monitor.
2. I am trying to play audio files in Audio folder using the command alsa_aplay It could able to make sound with lot of disturbance in it but it was not like music play, what might be the problem.
Thanks in advance for replying me back.
Sudheer. |
The BeagleBoard cannot support VGA. It is DVI-D only. If you have a DVI-D to VGA active converter, that will work.
