Unable to export UART channel. BBIO Adafruit
I’m using ubuntu 14.04.2 and Adafruit BBIO library.
When i execute: (https://learn.adafruit.com/setting-up-io-python-library-on-beaglebone-black/uart)
UART.setup(“UART4”)
i detect this error
RuntimeError: Unable to export UART channel.
this is the print of: dmesg | grep tty
[ 0.000000] Kernel command line: console=ttyO0,115200n8 quiet drm.debug=7 capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4 root=UUID=854463c0-6305-4e7b-b9e7-d2edbfa8b232 ro rootfstype=ext4 rootwait fixrtc quiet
[ 0.000426] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 2.654234] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250
[ 2.671940] console [ttyS0] enabled
[ 2.673157] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a 8250
[ 2.674056] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a 8250
[ 2.674871] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a 8250
[ 2.675645] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 62, base_baud = 3000000) is a 8250
this is the print of: ls -l /dev/tty*
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO0 → ttyS0
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO1 → ttyS1
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO2 → ttyS2
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO4 → ttyS4
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO5 → ttyS5
crw-rw---- 1 root tty 4, 64 May 14 15:20 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 May 14 15:19 /dev/ttyS1
crw-rw---- 1 root dialout 4, 66 May 14 15:19 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 May 14 15:19 /dev/ttyS3
crw-rw---- 1 root dialout 4, 68 May 14 15:19 /dev/ttyS4
this is the print of: uEnv.txt
uname_r=3.14.37-ti-r57
#dtb=
cmdline=quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=quiet video=HDMI-A-1:1024x768@60e
##Example
#cape_disable=capemgr.disable_partno=
optargs=quiet drm.debug=7 capemgr.enable_partno=BB-UART4
##enable BBB: eMMC Flasher:
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
uuid=854463c0-6305-4e7b-b9e7-d2edbfa8b232
Thank you,
Alessio
UART.setup(“UART4”)
i detect this error
Well going by what little information is at hand I can only guess that this “tutorial” is based on the 3.8.x kernel where there is a capemgr. kernel 3.14.x does not have a capemgr. But judging by the error output, this is exactly what the “library” is trying to do. Use capemgr through some sort of abstraction.
Again though, this is working with the data at hand. As I know absolutely nothing about this framework, library, or whatever it is. You should probably contact the author as to why your code / configuration is not working.
