I am doing the kernel build from what I think is Robert’s latest from git.
This is https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-rt-4.9.y.
I do the build in a Debian Jessie Virtual Box image.
I just do the build_deb.sh script and I get the following in the deploy folder:
linux-libc-dev_1cross_armhf.deb
linux-headers-4.9.32-ti-rt-r41_1cross_armhf.deb
linux-firmware-image-4.9.32-ti-rt-r41_1cross_armhf.deb
linux-image-4.9.32-ti-rt-r41_1cross_armhf.deb
I use FileZilla and copy the 4 files to the /var/cache/apt/archives folder on the Beaglebone Green.
I then do the following:
sudo dpkg -i linux-libc-dev_1cross_armhf.deb
sudo dpkg -i linux-headers-4.9.32-ti-rt-r41_1cross_armhf.deb
sudo dpkg -i linux-firmware-image-4.9.32-ti-rt-r41_1cross_armhf.deb
sudo dpkg -i linux-image-4.9.32-ti-rt-r41_1cross_armhf.deb
It looks like everything installs properly except for a couple of driver issues in the linux image looks like they relate to temperature drivers.
I do a reboot
and
the uname -a is this
Linux beaglebone 4.9.32-ti-rt-r41 #1 SMP PREEMPT RT Fri Jun 23 11:59:11 EDT 2017 armv71 GNU/Linux
When I do the lsmod this is what I’m seeing
Module Size Used by
omap_aes_driver 23718 0
crypto_engine 7035 1 omap_aes_driver
omap_sham 26574 0
omap_rng 5544 0
rng_core 8523 1 omap_rng
usb_f_acm 8217 1
u_serial 12927 3 usb_f_acm
usb_f_rndis 25931 1
g_multi 5958 0
usb_f_mass_storage 50190 2 g_multi
u_ether 13883 2 g_multi,usb_f_rndis
libcomposite 54819 4 usb_f_acm,usb_f_mass_storage,g_multi,usb_f_rndis
cpufreq_ondemand 7899 1
cpufreq_userspace 3807 0
cpufreq_conservative 4417 0
cpufreq_powersave 1567 0
evdev 13460 1
tps65217_charger 5088 0
uio_pdrv_genirq 4045 0
uio 10625 1 uio_pdrv_genirq
A few months ago I was running the remote_proc to the PRUs on a pre-built version I think it was somewhere in the V4.1 range but without the PREEMPT_RT.
I wanted to test my PRU code on a PREEMPT build but this is the only way I could figure out to do it.
Is there something I’m missing when I do the build to enable the remote_proc. The only change I made in the menu_config was to enable the remote_proc, I think it was in the drivers section.
The modprobe pru_rproc and the rmmod pru_rproc are no longer functional in this version.
Here is what’s in the dmesg
root@beaglebone:/var/lib/cloud9# dmesg | grep pru
[ 3.716208] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 3.751488] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
[ 3.761517] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
[ 3.772938] remoteproc remoteproc1: 4a334000.pru0 is available
[ 3.778990] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a334000 probed successfully
[ 3.791078] remoteproc remoteproc2: 4a338000.pru1 is available
[ 3.797109] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a338000 probed successfully
Any help here is greatly appreciated
