Hey All,
I’m a newb on Linux and having issues getting WiFi to work using the latest Debain image Debian 9.1 2017-08-31 4GB SD LXQT (Stretch). When I try to see the the network interfaces using ifconfig I get only the following 4 and no wlan-
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
I don’t know if this will help but the eprom from my version.sh file is -
eprom:[A335BNLTBBWG0491
Any thoughts on how to fix this or should I start all over again with a new image flash? Any tips/resources on Bluetooth communication on BBBW will also be appreciated.
another case of mis-programed:
GND TP1 then run as root:
dd if=/opt/scripts/device/bone/bbbw-eeprom.dump
of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom
reboot and everything will be okay..
Hi Robert,
I have a BBB wireless that also seems to have the same problem as Hamze.
How do I confirm whether or not I also have a faulty eprom version?
Here are some details relating to my installation …
Hi All,
Same problem here. Which is TP1. I could not find it on the header information .
Look at the pcb, it's on the silkscreen..
Still no luck .
debian@beaglebone:~$ sudo /opt/scripts/tools/version.sh
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1 ) Respect the privacy of others.
#2 ) Think before you type.
#3 ) With great power comes great responsibility.
[sudo] password for debian:
git:/opt/scripts/:[2ce750d881941c5189db9e189af90517e11c079f]
eeprom:[A335BNLT00C05315BBBK1677]
dogtag:[BeagleBoard.org Debian Image 2017-08-31]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2017.09-rc2-00002-g7c9353]
kernel:[4.9.45-ti-r57]
nodejs:[v6.11.2]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo]
pkg:[bb-cape-overlays]:[4.4.20170728.0-0rcnee1~stretch+20170728]
pkg:[bb-wl18xx-firmware]:[1.20170829-0rcnee1~stretch+20170829]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee0~stretch+20170830]
debian@beaglebone:~$ iwconfig
eth0 no wireless extensions.
usb0 no wireless extensions.
usb1 no wireless extensions.
lo no wireless extensions.
can0 no wireless extensions.
can1 no wireless extensions.
I downloaded the Debain image Debian 9.1 2017-08-31 4GB SD LXQT (Stretch)
debian@beaglebone:~$ connmanctl
tether wifi off
Error disabling wifi tethering: Method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
enable wifi
Error wifi: Method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
scan wifi
Error /net/connman/technology/wifi: Method “Scan” with signature “” on interface “net.connman.Technology” doesn’t exist
agent on
Agent registered
What do you mean? "you" ^^^ have a BeagleBone Black, NOT the
BeagleBone Black Wireless
The "BeagleBone Black Wireless" is a new model:
lucien
November 17, 2017, 1:15am
9
Chiming in, this combined with updating to the latest provided release of debian stretch fixed the wireless issues.
My /opt/scripts/tools/version.sh after applying the fix for posterity:
eeprom:[A335BNLTBWA50000BBWG*]
nodejs:[v6.11.2]
Thank you!
William
November 20, 2017, 10:32am
10
Hello, this is what I have done, no result for now:
1. Flashed BBBW with last image Debian 9.2 2017-10-10 4GB SD IoT
2. Grounded TP1
3.
4.
5.
root@beaglebone:~# sudo /opt/scripts/tools/version.sh git:/opt/scripts/:[d36fe9a7be9ebfc872b10a470e904ab4c61c4516] eeprom:[A335BNLTBWA51712EW005259] dogtag:[BeagleBoard.org Debian Image 2017-10-10] bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2017.09-00002-g0f3f1c7907] kernel:[4.4.91-ti-r133] nodejs:[v6.11.4] device-tree-override:[dtb=am335x-boneblack-emmc-overlay.dtb] pkg:[bb-cape-overlays]:[4.4.20171013.2-0rcnee1~stretch+20171013] pkg:[bb-wl18xx-firmware]:[1.20170829-0rcnee1~stretch+20170829] pkg:[firmware-ti-connectivity]:[20170823-1rcnee0~stretch+20170830]
6. Reboot
After reboot:
root@beaglebone:~# cat /proc/device-tree/model TI AM335x BeagleBone Black
root@beaglebone:~# iwconfig
It seems that no wireless interface is detected. Am I missing something?
are you using beagle bone black or beagle bone black wireless .wireless works only on beaglebone wireless
William
November 20, 2017, 10:45am
12
I am using a BB wireless from element14.
luni, 20 noiembrie 2017, 12:39:15 UTC+2, Reshmi Chandran a scris:
^^^ so you just forced it to be a BeagleBone Black here...
YOU need to use:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
This will give you what you want:
disable_uboot_overlay_video=1
William
November 20, 2017, 1:10pm
14
Added
to /boot/uEnv.txt
Now it does not boot, leds for BT, WL and USR0 stay on.
beaglebone login: [ 64.841141] Error: Driver ‘ecap’ is already registered, aborting…
[ 65.139009] Error: Driver ‘ecap’ is already registered, aborting…
This is last messages on debug pins.
“login” yes ‘clearly’ it did not boot… end sarcasm…
What’s your real issue, as it did boot.
William
November 21, 2017, 12:15pm
16
Ok, my mistake, I ‘appreciate’ your sarcasm, but still cannot see any wifi interface.
How can I find the real issue since I cannot ssh connect to BB?
I only have debug messages and a stuck BB.
luni, 20 noiembrie 2017, 16:21:21 UTC+2, RobertCNelson a scris:
Okay, now with your /boot/uEnv.txt changes, let's see version.sh again:
William
November 21, 2017, 2:16pm
18
BB is completely freeze with those leds on.
Tried to re-flash, same issue.
I am not able to run any script.
William
November 22, 2017, 11:18am
20
I always use a 5V power supply.
Got the image, flashed SD with Etcher, flashed the BBBW.
Same result as before: it runs until “beaglebone login:”, then freezes.
bbbw_debug_messages - Pass: 1234
It can be a problem with my board? I have only one to test.
Thank you for your support.
