Probably too late now, but I have to wonder why you are starting the
procedure with a flasher-image.
I'd consider it safer (presuming one has a working eMMC already) to use
a "run on SD card" image for testing. That way, if it hangs, one can remove
the SD card and reboot to the working image.
Only after getting the SD card image to run properly would I convert it
to a flasher.
I have only a 5V TTL serial cable, used only for receiving debug messages on PC (I don’t want to burn something connecting the TX and V since voltage is different).
For a normal SSH connection I use the mini USB cable and here is the problem.
Since now I used with no problem BBB rev C and BBB industrial.
Also this BBBW worked properly when recognized as BBB. (with #enable_uboot_overlays=1 disabled from /boot/uEnv.txt)
I was also facing same issue. I tried with different images( 8iot and LXQT.6,8.7,9.1,9.2,9.3) debian LXQT 8.6 able to detect the wlna0 some times ,But unable to configure the wifi using connmanctl commands
Last login: Sun Nov 6 15:29:31 UTC 2016 on ttyGS0
Linux beaglebone 4.4.30-ti-r64 #1 SMP Fri Nov 4 21:23:33 UTC 2016 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
connmanctl> scan wifi// not working connmanctl> scan wifi// not working connmanctl> scan wifi// not working connmanctl> scan wifi // not working
Here the image details
uname -a
Linux beaglebone 4.4.30-ti-r64 #1 SMP Fri Nov 4 21:23:33 UTC 2016 armv7l GNU/Lix
debian@beaglebone:~$ cat /etc/dogtag BeagleBoard.org Debian Image 2016-11-06
scan wifi
interface configuration ( /et/networ/interface)
iface wlan0 inet dhcp
auto wlan0
wpa-ssid “xxxx”
wpa-psk “xxxxxx”
