I am unable to interface Beaglebone Black with LCD monitor. I have tried with updating latest eMMC and micro SD card updates. But all in vein.
I also tried to force resolution using serial cable.
This is my output
U-Boot SPL 2013.04-dirty (May 20 2013 - 14:30:06)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (May 20 2013 - 14:30:06)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
99 bytes read in 3 ms (32.2 KiB/s)
4270840 bytes read in 764 ms (5.3 MiB/s)
24129 bytes read in 46 ms (511.7 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88e40
Starting kernel …
[ 0.193999] omap2_mbox_probe: platform not supported
[ 0.204548] tps65217-bl tps65217-bl: no platform data provided
[ 0.281140] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.318247] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.355355] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.392463] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.412475] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.422092] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 0.428867] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.451512] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.515925] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 0.527640] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 0.534955] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.619008] tilcdc 4830e000.fb: timeout waiting for framedone
systemd-fsck[85]: Angstrom: clean, 50616/218160 files, 304989/872448 blocks
.—O—.
.-. o o
__ | —'| ‘–.| .-’| | |— || --‘| | | ’ | | | |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2012.12 - Kernel 3.8.13
beaglebone login: [ 13.084344] libphy: PHY 4a101000.mdio:01 not found
[ 13.089446] net eth0: phy 4a101000.mdio:01 not found on slave 1
.—O—.
.-. o o
beaglebone login: root
Last login: Sat Jan 1 00:04:40 UTC 2000 on ttyO0
root@beaglebone:~# export XAUTHORITY=ls /var/run/gdm/auth-for-root-*/database
ls: cannot access /var/run/gdm/auth-for-root-*/database: No such file or directory
root@beaglebone:~# export DISPLAY=:0.0
root@beaglebone:~# xrandr --output HDMI-0 --mode 720x480 --rate 60
xrandr: cannot find mode 720x480
root@beaglebone:~#
I am using micro HDMI to HDMI converter cable bought from Crazy pi. My monitor is acer, it does not have hdmi port. So i am using HDMI to VGA converter. I also tried all resolutions, but all in vein.
I also tried the following command:
root@beaglebone:~# “cd /sys/class/drm/card0/card0-HDMI-A-1/”
-sh: cd /sys/class/drm/card0/card0-HDMI-A-1/: No such file or directory
root@beaglebone:~# cd /sys/class/drm/card0/card0-HDMI-A-1/
root@beaglebone:/sys/class/drm/card0/card0-HDMI-A-1# parse-edid edid
parse-edid: parse-edid version 2.0.0
parse-edid: IO error reading EDID
Kindly guide me to rectify the problem
