unable to launch docker on Beaglebone AI 64
Unable to launch the docker service
Immediately after fresh installation
debian@BeagleBone-AI64:~$ systemctl status docker.service
● docker.service - Docker Application Container Engine
     Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sat 2024-06-08 15:03:52 UTC; 3min 39s ago
TriggeredBy: ● docker.socket
       Docs: https://docs.docker.com
   Main PID: 5050 (code=exited, status=1/FAILURE)
        CPU: 261ms
Jun 08 15:03:52 BeagleBone-AI64 systemd[1]: Failed to start Docker Application Container Engine.
Jun 08 15:03:52 BeagleBone-AI64 systemd[1]: docker.service: Scheduled restart job, restart counter is at>
Jun 08 15:03:52 BeagleBone-AI64 systemd[1]: Stopped Docker Application Container Engine.
Jun 08 15:03:52 BeagleBone-AI64 systemd[1]: docker.service: Start request repeated too quickly.
Jun 08 15:03:52 BeagleBone-AI64 systemd[1]: docker.service: Failed with result 'exit-code'.
Can anyone help me with regards to this.
Which kernel? uname -r this usually is a missing kennel option…
Run this checker… moby/contrib/check-config.sh at master · moby/moby · GitHub
My kernel version is 6.10.0-rc1-arm64-r1
Running the checker, gave the below output
info: reading kernel config from /proc/config.gz ...
Generally Necessary:
- cgroup hierarchy: cgroupv2
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled (as module)
- CONFIG_BRIDGE: enabled (as module)
- CONFIG_BRIDGE_NETFILTER: enabled (as module)
- CONFIG_IP_NF_FILTER: enabled (as module)
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
- CONFIG_NETFILTER_XT_MARK: enabled (as module)
- CONFIG_IP_NF_NAT: enabled (as module)
- CONFIG_NF_NAT: enabled (as module)
- CONFIG_POSIX_MQUEUE: enabled
Optional Features:
- CONFIG_USER_NS: enabled
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: missing
    (cgroup swap accounting is currently enabled)
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: missing
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: enabled
- CONFIG_NET_CLS_CGROUP: missing
- CONFIG_CGROUP_NET_PRIO: missing
- CONFIG_CFS_BANDWIDTH: missing
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: missing
- CONFIG_IP_NF_TARGET_REDIRECT: missing
- CONFIG_IP_VS: enabled (as module)
- CONFIG_IP_VS_NFCT: missing
- CONFIG_IP_VS_PROTO_TCP: missing
- CONFIG_IP_VS_PROTO_UDP: missing
- CONFIG_IP_VS_RR: missing
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
  - "overlay":
    - CONFIG_VXLAN: missing
    - CONFIG_BRIDGE_VLAN_FILTERING: enabled
      Optional (for encrypted networks):
      - CONFIG_CRYPTO: enabled
      - CONFIG_CRYPTO_AEAD: enabled
      - CONFIG_CRYPTO_GCM: enabled (as module)
      - CONFIG_CRYPTO_SEQIV: missing
      - CONFIG_CRYPTO_GHASH: enabled (as module)
      - CONFIG_XFRM: missing
      - CONFIG_XFRM_USER: missing
      - CONFIG_XFRM_ALGO: missing
      - CONFIG_INET_ESP: missing
  - "ipvlan":
    - CONFIG_IPVLAN: missing
  - "macvlan":
    - CONFIG_MACVLAN: enabled (as module)
    - CONFIG_DUMMY: missing
  - "ftp,tftp client in container":
    - CONFIG_NF_NAT_FTP: missing
    - CONFIG_NF_CONNTRACK_FTP: missing
    - CONFIG_NF_NAT_TFTP: missing
    - CONFIG_NF_CONNTRACK_TFTP: missing
- Storage Drivers:
  - "aufs":
    - CONFIG_AUFS_FS: missing
  - "btrfs":
    - CONFIG_BTRFS_FS: enabled (as module)
    - CONFIG_BTRFS_FS_POSIX_ACL: enabled
  - "devicemapper":
    - CONFIG_BLK_DEV_DM: enabled (as module)
    - CONFIG_DM_THIN_PROVISIONING: missing
  - "overlay":
    - CONFIG_OVERLAY_FS: enabled (as module)
  - "zfs":
    - /dev/zfs: missing
    - zfs command: missing
    - zpool command: missing
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
@malto101 and it would help if i actually setup the 6.10.x debian meta package:
sudo apt update
sudo apt-get install bbb.io-kernel-6.10-k3
