It seems the installation has been successful, no errors loading
kernel and mounting FS, but I can't see the GUI on my dvi monitor.
I've attached the bb to a DVI monitor by a HDMI-DVI cable. I also have
attached the bb to a PC (RS232-USB) in order to debug. When I turn on
the bb I can see uboot and kernel booting in the shell of the PC and
nothing in the DVI monitor. When the FS is booting, the monitor turns
on and I can see the same image in both: PC and dvi monitor. Later, I
can see in the dvi monitor how the GUI begin to boot but few seconds
later the image disappears.
In abstract:
- Ubuntu seems to be well installed.
- DVI monitor runs ok (at least text).
- GUI doesn't run.
I've proved with 3 different monitors and 2 different HDMI-DVI cables,
but still not working.
Everything is good up to hear and exactly what i'd expect you to see
with those images I've posted..
Later, I
What 'gui' are you running that isn't appearing? as the minimal image
by default doesn't have a gui...
In abstract:
- GUI doesn't run.
Anyway... I formatted the SD and installed all the system again:now I
can see Ubuntu's Desktop
By now the only inconvenience I can see is the color depth: I'm not
sure if the monitor works ok (never used til now) or I have to change
from RG565 to RGB666 or RGB888. I will prove...
