Unable to read "boot.scr"
trying to boot linux on beable board with angstrom demo. I see following errors. says unable to read boot.scr , cannot get kerner image etc
any solution for the problem??
mmc1 is available
reading boot.scr
** Unable to read “boot.scr” from mmc 0:1 **
reading uImage
** Unable to read “uImage” from mmc 0:1 **
Booting from nand …
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Wrong Image Format for bootm command
ERROR: can’t get kernel image!
OMAP3 beagleboard.org #
-aamer
Dear Aamer:
I suspect U-Boot is trying to load uImage.bin and your image is named uImage (or vice versa).
Charles
Hi Charles,
Thank you for the reply.
I have tried it, but i see the same problem. let me put in detail
what i have done until now. verified initial BB boot without using SD
card. then partitioned SD card as per instructions (on linux PC) at
http://code.google.com/p/beagleboard/wiki/LinuxBootDiskFormat
added latest files from http://www.angstrom-distribution.org/demo/beagleboard/
to fat32 part and ext3 part.
powered up BB, then hit key to stop auto boot , setenv for bootargs,
boot cmd and saved it using saveenv.
later restarted the board while pressing user button. now i see
following errors on hyperterminal (windows PC)
Unknown command 'mmcinit' - try 'help'
** Unable to use mmc 0:1 for fatload **
ERROR: can't get kernel image!
seems some prob with 'mmcinit' command what i have used during setting
bootargs and boot cmd.
any kind of suggestion will be appreciated.
-aamer
There is no such command anymore as 'mmcinit'. It's 'mmc init' nowadays.
Dear Antti,
that works!! still could not see messages of kernel booting, but the following:
mmc1 is available
usage: fatload <dev[:part]> [bytes]
does the below messages show any problem with fatload ? i did it as given below
setenv bootcmd ‘mmc init; fatload mmc 0 80300000 uImage.bin; bootm 80300000’
Thanks in advance for your help.
-aamer
Hi
mmc1 is available
Try setenv bootcmd ‘mmc init; fatload mmc 0 0x80300000 uImage.bin; bootm 0x80300000’
HTH
Kedar
Hi Kedar,
it doesnt work. i get the same fatload message…
this is what i have tried
OMAP3 beagleboard.org # setenv bootargs 'console=ttyS0, 115200n8
root=/dev/mmcblk0p2 rw rootwait’
OMAP3 beagleboard.org # setenv bootcmd ‘mmc init; fatload mmc 0 0x80300000
OMAP3 beagleboard.org # boot
for info, i have used Angstrom-Beagleboard-demo-image-glibc-ipk-2009.X-unstable-20090903-beagleboard.rootfs.tar.bz2 for partition 2 and uImage-2.6.29-r44-beagleboard.bin for partition 1 and renamed it to uImage.bin as the U-boot prompt was looking for uImage.bin name
Any suggestions?
-aamer
finally this worked!!
setenv bootargs ‘console=ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait omapfb.video_mode=1024x768MR-16@60’
