Looks like CMEM library is not able to link with OpenCV. I copied cmem.h & cmem.a470MV lib into Opencv lib folder. But no luck.
Anybody have any idea what’s going wrong ? I will appreciate your help.
home/metrans/setup-scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/beagleboard/usr/share/ti/ti-linuxutils-tree/packages/ti/sdo/linuxutils/cmem/include: No such file
should be easy to check if that is the correct place where you
have linuxutils...
I would suggest you use /home/... and not home/...
Vladimir,
I tried to use /home/… . But I am ended up with this error . I don’t know what’s going wrong ? Why I am getting following errors
…/…/lib/libopencv_core.so.2.3.1: undefined reference to CMEM_init' ../../lib/libopencv_core.so.2.3.1: undefined reference to CMEM_alloc’ …/…/lib/libopencv_core.so.2.3.1: undefined reference to `CMEM_free’
I am following the steps given in above tutorial. How come I build opencv without cmem to start with Or just use the opencv binaries ?
Could you explain little bit more ?
Vladimir,
I tried to use /home/... . But I am ended up with this error http://pastebin.com/nHSBHab1. I don't know what's going
../../lib/libopencv_core.so.2.3.1: undefined reference to `CMEM_init' ../../lib/libopencv_core.so.2.3.1: undefined
reference to `CMEM_alloc' ../../lib/libopencv_core.so.2.3.1: undefined reference to `CMEM_free'
Does anybody have solution for this ?
the instructions you are following are almost 2 years old, so they could
be slightly outdated or stuff could have changed. Unless somebody else
sites down and tries to re-do what you did, It's hard to tell what
is going wrong in your case. Otherwise, the usual guidelines about
"making stuff compile" apply here, but please understand there is no
definite guide.
As for the error: undefined reference to `CMEM_free'
it looks like you are not linking against the CMEM library.
Yes, I'm having the same error when I try to compile onboard omapfbplay with cmem option enabled. The cmem kernel module is installed and running but I can't find a trace of the cmem shared library, nor in my system neither in the cmem bitbake recipe (that I've used to build the module)
Hello Everybody,
Finally, I am able tot run bitbake opencv successfully. I solved this problem. I was doing stupid mistake. If you look at these two commands. These are different, not the same.
I wasn’t focusing on difference between start of these commands which is bold here. I was using sed -i '/^CXX_FLAGS/s:$: -I in second command which should have only sed -i '/^/s:$:
sed -i '/^CXX_FLAGS/s:$: -I</home/metrans/setup-scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/beagleboard/usr/share/ti/ti-linuxutils-tree/packages/ti/sdo/linuxutils/cmem/include:g’ opencv/modules/core/CMakeFiles/opencv_core.dir/flags.make
sed -i '/^/s:$: /home/metrans/setup-scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/beagleboard/usr/share/ti/ti-linuxutils-tree/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV:g’ opencv/modules/core/CMakeFiles/opencv_core.dir/link.txt
Thanks everybody for your pointers. I hope this will help other people.
Thanks so much for the help.
This was my problem also. I had to fix a number of issues to get OpenCV to build and I ended up manually editing those two files.
At first I had added the cmem.a.a470MV file as an include “-I” rather than an object.
It built, but then the ‘undefined reference’ error results, eventually.
I went back, added that file at the end of the long string of colons, rebuilt, copied the library over, and it works.
-Len
