Undefined symbols in jackd (jackmp svn branch)
Beagleboard C3 with Narcissus Angstrom distro installed. I don't have jack from the distro installed.
If I build jackmp with "./waf configure --alsa", "./waf build", "./waf install", when it runs I get undefined symbol errors as there are no symbols defined.
root@beagleboard:/usr/src/jackmp# jackd -m -Phw:0 -Chw:1 -r48000 -n3&
root@beagleboard:/usr/src/jackmp# jackdmp 1.9.7
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2010 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
jackd: symbol lookup error: jackd: undefined symbol: jackctl_server_create
None of the following symbols are defined.
root@beagleboard:/usr/src/jackmp# nm /usr/local/bin/jackd|grep U
          U _Z27jackctl_parse_driver_paramsP14jackctl_driveriPPc
          U _ZNSt8ios_base4InitC1Ev@@GLIBCXX_3.4
          U _ZNSt8ios_base4InitD1Ev@@GLIBCXX_3.4
          U __aeabi_atexit@@GLIBC_2.4
          U __aeabi_unwind_cpp_pr0@@GCC_3.5
          U __libc_start_main@@GLIBC_2.4
          U abort@@GLIBC_2.4
          U fprintf@@GLIBC_2.4
          U fwrite@@GLIBC_2.4
          U getopt_long@@GLIBC_2.4
          U jack_set_error_function
          U jackctl_driver_get_name
          U jackctl_driver_get_parameters
          U jackctl_parameter_get_name
          U jackctl_parameter_set_value
          U jackctl_server_add_slave
          U jackctl_server_create
          U jackctl_server_destroy
          U jackctl_server_get_drivers_list
          U jackctl_server_get_parameters
          U jackctl_server_start
          U jackctl_server_stop
          U jackctl_setup_signals
          U jackctl_wait_signals
          U malloc@@GLIBC_2.4
          U memcpy@@GLIBC_2.4
          U memset@@GLIBC_2.4
          U printf@@GLIBC_2.4
          U silent_jack_error_callback
          U strcmp@@GLIBC_2.4
          U strncpy@@GLIBC_2.4
          U strtol@@GLIBC_2.4
          U tolower@@GLIBC_2.4
beagleboard:/usr/src/jackmp# CC="gcc -E" CXX="g++ -E" ./waf configure --alsa
Linux detected
Checking for compiler version : ok 4.3.3
Checking for program cpp : ok /usr/bin/cpp
Checking for program ar : ok /usr/bin/ar
Checking for program ranlib : ok /usr/bin/ranlib
Checking for g++ : ok
Checking for gcc : ok
Checking for header samplerate.h : not found
Checking for alsa >= 1.0.18 : ok
Checking for libfreebob >= 1.0.0 : Package "libfreebob (>= 1.0.0)" could not be found or the found version is too old.
Checking for libffado >= 1.999.17 : Package "libffado (>= 1.999.17)" could not be found or the found version is too old.
Checking for header sndfile.h : not found
Checking for celt >= 0.5.0 : Package "celt (>= 0.5.0)" could not be found or the found version is too old.
Checking for header ncurses.h : not found
Checking for library readline : not found
Checking for celt >= 0.7.0 : Package "celt (>= 0.7.0)" could not be found or the found version is too old.
Are you trying to mix C and C++ implementations? From my experience
with jack 1.x many symbols come from the libjack shared library rather
than from jackd itself because in some cases clients need to activate
jackd.
Is there a reason that jackd from the ipkg is unsuitable? It works for
me (now that the defaults are patched).
jackd.
Some of the sources are C++ and some are C
slipstream:/home/lancelot/ftp/JUL10/jackmp # ls linux/alsa
alsa_driver.h alsa_midi_impl.h alsa_rawmidi.c bitset.h generic_hw.c hammerfall.h hdsp.c ice1712.c JackAlsaAdapter.cpp JackAlsaDriver.cpp jslist.h midi_unpack.h usx2y.c
alsa_midi.h alsa_midi_jackmp.cpp alsa_seqmidi.c generic.h hammerfall.c hardware.h hdsp.h ice1712.h JackAlsaAdapter.h JackAlsaDriver.h midi_pack.h .svn usx2y.h
Jack 1.x or at least the packages in the narcissus version lack certain utilities.
# ls /usr/local/bin/jack*
/usr/local/bin/jack_alias /usr/local/bin/jack_cpu /usr/local/bin/jack_disconnect /usr/local/bin/jack_lsp /usr/local/bin/jack_monitor_client /usr/local/bin/jack_samplerate /usr/local/bin/jack_test /usr/local/bin/jack_wait
/usr/local/bin/jack_bufsize /usr/local/bin/jack_cpu_load /usr/local/bin/jack_evmon /usr/local/bin/jack_metro /usr/local/bin/jack_multiple_metro /usr/local/bin/jack_server_control /usr/local/bin/jack_thru /usr/local/bin/jack_zombie
/usr/local/bin/jack_connect /usr/local/bin/jackd /usr/local/bin/jack_freewheel /usr/local/bin/jack_midiseq /usr/local/bin/jack_netsource /usr/local/bin/jack_showtime /usr/local/bin/jack_transport
/usr/local/bin/jack_control /usr/local/bin/jack_delay /usr/local/bin/jack_load /usr/local/bin/jack_midisine /usr/local/bin/jack_rec /usr/local/bin/jack_simple_client /usr/local/bin/jack_unload
Yes, see above. I at least need jack_connect, jack_lsp, jack_samplerate and jack_load.
Building the same source on the x86_64 platform, I get no errors from jackd.
Regards
Sid.
The ipkg repo gives at least jackd, jack_connect and jack_lsp as these
are the elements I currently use frequently.
I don't have my board with me so I cannot be sure of the others.
I tried the ipk packages from narcissus and they didn't show them.
I've since installed Ubuntu and jackd starts OK, though jack_lsp doesn't list any ports, it just hangs with strace showing the following and I have to terminate it with ^C.
mmap2(NULL, 524288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x402be000
mprotect(0x402be000, 4096, PROT_NONE) = 0
clone(Process 708 attached
child_stack=0x4033cf98, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x4033d4c8, tls=0x4033d920, child_tidptr=0x4033d4c8) = 708
[pid 707] nanosleep({0, 1000000}, NULL) = 0
[pid 707] nanosleep({0, 1000000}, <unfinished ...>
[pid 708] set_robust_list(0x4033d4d0, 0xc) = 0
[pid 708] futex(0x1f51c, FUTEX_WAIT_PRIVATE, 1, NULL <unfinished ...>
[pid 707] <... nanosleep resumed> NULL) = 0
[pid 707] rt_sigprocmask(SIG_BLOCK, [PIPE], [], 8) = 0
[pid 707] socket(PF_FILE, SOCK_STREAM, 0) = 3
[pid 707] getuid32() = 0
[pid 707] connect(3, {sa_family=AF_FILE, path="/dev/shm/jack_default_0_0"}, 110^C <unfinished ...>
Process 708 detached
Regards
Sid.
I had to patch the jackd defaults to make capture work on the beagle.
The archive of this (beagleboard) list has my mail that describes the
magic jackd command-line parameters to get capture to work. Linked
below.
http://groups.google.com/group/beagleboard/browse_thread/thread/a634a3986d50f92d/a34125442f5cee80?lnk=gst&q=jackd#a34125442f5cee80
I decided to install Ubuntu on a spare 16G SD, jackmp builds and installs, jackd runs.
root@beagleboard:~# jack_lsp
^C
root@beagleboard:~# ps fax|grep jack
   637 ttyS2 RLl 1:08 \_ jackd -m -r -dalsa -Phw:0 -Chw:1 -r48000 -p1024 -s -n3
   642 ttyS2 S+ 0:00 \_ grep --color=auto jack
^C
jack_lsp just hangs there until ^C.
aplay works for me on Angstrom via the LINE OUT jack to headphones. I
don't use pulseaudio. I run without a screen so everything I do is via
ssh command line.
I had to run alsamixer and turn up the gain on a few DAC elements.
Forgotten which ones, but I remember it was pretty simple to find
which ones were effective.
I have not been able to get capture gain to work, but its default
levels are OK for my purposes.
alsamixer settings
AVADC HiFi/hig or Voice hi
Carkit 100<>100
Codec Option1 or Option 2
DAC Voic 100
DAC1 Ana 100 <> 100
DAC1 Dig 100 <> 100
DAC2 Ana 100 <> 100
DAC2 Dig 100 <> 100
Earpiece 100
aplay jet.wav >/dev/dsp no sound.
I'll try the Angstrom disto later.
Regards
Sid.
