Understanding how to partition the eMMC/SD card
Hi
I’ve been following the steps at https://eewiki.net/display/linuxonarm/BeagleBone+Black; Trying build the latest mainline kernel with the minimum Debian filesystem.
I don’t quite understand what is happening in the following steps under “Setup microSD/SD card”
sudo dd if=/dev/zero of=${DISK} bs=1M count=10
sudo dd if=./u-boot/MLO of=${DISK} count=1 seek=1 conv=notrunc bs=128k
sudo dd if=./u-boot/u-boot.img of=${DISK} count=2 seek=1 conv=notrunc bs=384k
Create Partition Layout:
sudo sfdisk --in-order --Linux --unit M ${DISK} <<-EOF
1,0x83,*
EOF
Format Partitions:
for: DISK=/dev/mmcblk0
sudo mkfs.ext4 ${DISK}p1 -L rootfs
I realise the a card is being wiped and then formatted but I’m not sure why.
The default Debian sd card image (and other images I found) Have separate boot partition, however in this example only one partition is created.
Why is this tutorial different?
Is it just a new feature of U-boot?
Also after following the all the steps in the tutorial the the beagelbone black will boot from the SD card but it will hang on the line “net eth0: phy 4a101000.mdio:01 not found on slave 1” for about 30 sec before showing the login prompt but that is probably a question for another thread.
David
Hi
I've been following the steps at
I don't quite understand what is happening in the following steps under
"Setup microSD/SD card"
bs=384k
sudo sfdisk --in-order --Linux --unit M ${DISK} <<-__EOF__
1,0x83,*
__EOF__
Format Partitions:
I realise the a card is being wiped and then formatted but I'm not sure why.
It's the same setup used on 'newer' snapshots..
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Debian_Image_Testing_Snapshots
it's a feature available to newer ti bootrom's, (omap4 generation + )
which we are utilizing to make it easier for windows users to not
accidentally delete MLO/u-boot.img and soft-bricking there board.
black will boot from the SD card but it will hang on the line "net eth0: phy
4a101000.mdio:01 not found on slave 1" for about 30 sec before showing the
dhcp is still slow, it takes a few seconds for the eth0 to get an ip address.
Thanks that make sense.
Once the image is working is there a way to copy the SD card to the eMMC? The scripts at https://github.com/RobertCNelson/tools/blob/master/scripts don’t seem to work for the single partition image.
Regards
David
I should delete that repo..
use the file under /opt/scripts/
https://github.com/RobertCNelson/boot-scripts/tree/master/tools/eMMC
