Unexpected bitbake error! Please Help!
hii all,
i am trying to begin code development with oe and following the instructions on this wiki-page for a clean start-up.
http://elinux.org/BeagleBoardAndOpenEmbeddedGit
At the end of article the "bitbake console-image" command gives me that output:
hii all,
output:
ERROR: Openembedded's config sanity checker detected a potential
misconfiguration.
      Either fix the cause of this error or at your own risk disable
the checker (see sanity.conf).
      Following is the list of potential problems / advisories:
      Error, TMPDIR has changed location. You need to either move it
back to /home/ns/oe/tmp or rebuild
Try removing your OE tmpdir and starting over. It sounds like you moved it.
Philip
Deleting your old build dir helps too
понеделник, 13 октомври 2008 г., 23:29:22 UTC+3, serkan erdogan написа:
