Unexpected bitbake error! Please Help!
hii all,
i am trying to begin code development with oe and following the
instructions on this wiki-page for a clean start-up.
http://elinux.org/BeagleBoardAndOpenEmbeddedGit
At the end of article the "bitbake console-image" command gives me that
output:
I intentionally moved my TMPDIR and triggered a similar problem.
Here is how I fixed it:
edit the saved_tmpdir file under the new TMPDIR location.
Warning: Only do this if you’ve moved the entire TMPDIR. Otherwise you probably should do a full rebuild (remove everything under TMPDIR).
Thanks for sharing, it worked for me!
