Updating bootloader for emmc flasher and changing USB device name
I’ve updated the bootloader with:
sudo /opt/scripts/tools/developers/update_bootloader.sh
But when I run /opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh it looks like it pulls an older backup version from /opt/backup/uboot
I see that when I run the update script it downloaded the new files to a tmp directory. Is it just a matter of copying/renaming the files from the tmp directory to /opt/backup/uboot?
/tmp/tmp.pvzpjINf7p/dl:
MLO-am335x_evm-v2018.09-r7
bootloader-ng
u-boot-am335x_evm-v2018.09-r7.img
Secondly, when I plug the BBGW into a PC using the micro usb cable, Windows installs the drivers and eventually says something like “Device BeagleBoneGreen ready to use”. Can I change that name to something else?
Thanks.
Bump.
I've updated the bootloader with:
bootloader-ng
https://github.com/RobertCNelson/boot-scripts/commit/d9a7ff1063db8359841c0349caf0898fd0bbc452
Secondly, when I plug the BBGW into a PC using the micro usb cable, Windows installs the drivers and eventually says something like "Device BeagleBoneGreen ready to use". Can I change that name to something else?
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/am335x_evm.sh#L223
Still having some trouble with this.
  • I am running directly off eMMC (no SD) with the latest bootloader (sudo /opt/scripts/tools/developers/update_bootloader.sh)
  • Now I clone the eMMC to SD (/opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh)
  • Use the SD to clone a new board - this board now has an old bootloader and I need to run update_bootloader.sh again.
Thanks.
So we need a patch to "update_bootloader.sh" to update these two files then:
/opt/backup/uboot/MLO
/opt/backup/uboot/u-boot.img
This should do it..
https://github.com/RobertCNelson/boot-scripts/commit/73352cab7d3e0b9d344fc619a56eb9e7b311c598
Ok, so it is exactly what I thought needed to be done, but I don’t think the change you made to update_bootloader.sh is quite right. It didn’t overwrite the existing ‘MLO’ and ‘u-boot.img’ files in /opt/backup/uboot. Instead it created two new files ‘BOOT’ and ‘SPL’.
BEFORE:
/opt/backup/uboot# ls -l
total 492
-rw-r–r-- 1 root root 75208 Jan 28 2018 MLO
-rw-r–r-- 1 root root 422560 Jan 28 2018 u-boot.img
AFTER:
total 1024
-rw-r–r-- 1 root root 447292 Jan 14 16:14 BOOT
-rw-r–r-- 1 root root 90884 Jan 14 16:14 SPL
Thanks.
OKay fixed..
https://github.com/RobertCNelson/boot-scripts/commit/702a85c3ea80bf39c36f539e40dbd0e877b173dc
Before:
debian@test-bbb-1:/opt/scripts/tools$ ls -lh /opt/backup/uboot/
total 516K
-rw-r--r-- 1 root root 90K Jun 24 2018 MLO
-rw-r--r-- 1 root root 422K Jun 24 2018 u-boot.img
After:
total 532K
-rw-r--r-- 1 root root 89K Jan 14 17:30 MLO
-rw-r--r-- 1 root root 437K Jan 14 17:30 u-boot.img
