Updating Node.js on Angstrom Linux
Hi
I’m attempting to update Node.js on the latest distribution of Angstrom Linux, Cloud9 GNOME Image 2013.06.20. I’m trying to install from source, node-v0.10.13. I downloaded, and unpacked the archive and ran the first step and received this:
root@beaglebone:~/node_install/node-v0.10.13# ./configure
Traceback (most recent call last):
File “./configure”, line 14, in
from gyp.common import GetFlavor
File “./tools/gyp/pylib/gyp/init.py”, line 8, in
import gyp.input
File “./tools/gyp/pylib/gyp/input.py”, line 5, in
from compiler.ast import Const
ImportError: No module named compiler.ast
I’m assuming this is related to some python issue. My python version is:
root@beaglebone:~/node_install/node-v0.10.13# python -V
Python 2.7.3
Has anyone successfully upgraded Node.js on Angstrom Linux? Thanks for any advice.
I was able to clear up the above error by running,
opkg update
opkg install python-compiler
I had forgotten this step when I updated. However, still not able to successfully run the “make” step:
/usr/bin/python tools/gyp_node -f make
make -C out BUILDTYPE=Release V=1
make[1]: Entering directory `/home/root/node_install/node-v0.10.13/out’
make[1]: Warning: File `…/deps/openssl/openssl.gyp’ has modification time 426711353 s in the future
./tools/gyp_node -fmake --ignore-environment “–toplevel-dir=.” -I/home/root/node_install/node-v0.10.13/common.gypi -I/home/root/node_install/node-v0.10.13/config.gypi “–depth=.” “-Goutput_dir=/home/root/node_install/node-v0.10.13/out” “–generator-output=/home/root/node_install/node-v0.10.13/out” “-Dcomponent=static_library” “-Dlibrary=static_library” node.gyp
/bin/sh: ./tools/gyp_node: No such file or directory
make[1]: *** [Makefile] Error 127
make[1]: Leaving directory `/home/root/node_install/node-v0.10.13/out’
make: *** [node] Error 2
the “/tools/gyp_node” is present in the unpacked directory, perhaps I’m not going about this the right way. Anyone run into this?
